delete p/s pump + SLP pully ? how
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
1 - I want to delete my power steering pump
2 - install SLP underdrive pulley
but im new here and dont know what i need to order to finish this
if i removed the p/s pump i guess i need a shorter belt?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
if i install slp underdrive pully i have to change belts or what ?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
guys can u please just tell me what i should i do ?![Icon Rolleyes](https://ls1tech.com/forums/images/smilies2/icon_rolleyes.gif)
belt list i saw : from http://www.thunderracing.com/catalog...vid=3&pcid=113
11-378K4 A/C Belt for 25% Underdriven Harmonic Balancer Crank Pulley $17.99 Buy Wish
11-390K4 A/C belt for 1998-2002 LS1 F-body (factory length for standard diameter balancer) $15.99 Buy Wish
11-510K6 "Short Belt" for track use on LS1 F-body with underdrive crank pulley (power steering bypass)
$17.99 Buy Wish
11-755K6 Accessory Belt for 25% Underdriven Harmonic Balancer Crank Pulley and Overdrive Alternator Pulley, 1998-2002 LS1 F-body $39.99 Buy Wish
11-760K6 Accessory Belt for 25% Underdriven Harmonic Balancer Crank Pulley Only, 1998-2002 LS1 F-body $34.99 Buy Wish
11-770K6 Accessory Belt for 25% Underdriven Harmonic Balancer Crank Pulley and Underdriven Alternator Pulleys, 1998-2002 LS1 F-body $32.99 Buy Wish
11-790K6 Accessory belt for 1998-2002 LS1 F-body (factory length for standard diameter balancer)
And here the pulley:
SLP100221 98-02 LS1 F-Body Underdrive Pulley $179.95
from : http://www.speedinc.com/catagory.cfm?catagory=Engine
Do i need Alternator Mounting Kit ?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
best regards
$17.99 Buy Wish
best regards
if you have access to a second car here is what I would do. Install underdrive pulley. then take a piece of string run it exactly how a belt would rout after deleting the power steering. measure the length of the string. That will give you the excat lenght of the belt you need. after you have that run up anyparts store and tell them you want a six rib belt that is xxx long
I agree, you can just plug it off. Although it will eventually start to mess with the steering column if your doing a lot of dead stop turning. Getting a manual rack in the future would be a good idea.
i realy appreciate ur help guys
but i know the manual steering rack and will do it in future but now
i want to know
1 - delete my power steering pump
and i dont know how or what i need to order to finish this
if i removed the p/s pump i guess i need a shorter belt so is it here ?
thaaaaanx
i want to know
thaaaaanx
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
elias_799
01ssreda4
thank u guys, ill tell u the plan
i need to replace my p/s pump because its not working
and i use this car only for track and sometimes ( few times )for weekend but after midnight hehe
so im tring to remove p/s pump and test it if its gonna be oky for me
and need advice on how to:
01ssreda4
elias_799
01ssreda4
what i need to do if delete my power steering pump
and install SLP underdrive pulley
01ssreda4
for the underdrive pulley you will need to take the stock pulley of, you do that by using a puller (you can rent one or buy one at your local auto part store) then you install the underdrive pulley, you might need to hammer it a little you do that by taking a long socket place it around the hole on the pulley (make sure it is bigger the the hole in the pulley) and then you lightly tap the socket with preferably a rubber hammer. good luck. let us know how it went.
