Terrible Gas Mileage...suggestions?
Old 02-10-2009, 10:39 AM
Transam1's Avatar
Default Terrible Gas Mileage...suggestions?
99 trans am, automatic...when i was running mostly stock with 2.76's my average mpg was like 19-21 with a mix of HW and City driving...now after 3.43 gears, 224/230 581.588 114 cam, headers, ORY, QTP elec cutout, and tune i average 13-15mpg...and i recently took an interstate trip and got 19mpg...is this normal? i know people with 3.73 that get better gas mileage...also a recent factor might be the cold weather here? i dont know...any ideas? bad plugs or something?
Old 02-10-2009, 01:54 PM
twitchtwice's Avatar
how is your tune?
Old 02-10-2009, 02:04 PM
7camaro7's Avatar
holler at vince at trifectaperformance, he'll straighten you out
thunderstruck507's Avatar
my cam is similar but reverse split and I have been getting 24+ highway so something might be up
Old 02-10-2009, 02:06 PM
Racer383's Avatar
One thing I have noticed of late is not getting close to the same amount of miles from each tank. For me, I think some of it has to do with crap gas. Up to 10% can be alcohol now.
Old 02-10-2009, 02:23 PM
Mike@HSW's Avatar
LMAO...when this thread showed up as the most recent one on the main page, all it read was...Terrible Gas....I dont stop into this section that much, but i had to check that one out.
Old 02-10-2009, 04:06 PM
Transam1's Avatar
the tune is fine, only thing it does is die on me when i put it in gear every now in then because i dont have a stall yet... it does smell like gas when it idols but i though that was from having no cats... it runs 2100 at 70mph
Old 02-10-2009, 04:55 PM
Martin HD-28's Avatar
Check this out. I have AFR205's, SI6 cam, FAST 92/92, 4.10 gears, U/D pulley on an M6 and a superior tune and still get only 10-12 miles per gallon!!! I have just accepted that that's the price of driving such an awesome car.
Old 02-10-2009, 04:59 PM
bballr4567's Avatar
Then the tune isnt fine. It should run fine with the stock stall in there. You dont even have that "big" of a cam.
Id get it looked at by someone else for the tune to see what is up.
Old 02-10-2009, 05:30 PM
Transam1's Avatar
what do u mean it should run fine, after i did the upgrades and tune and stuff i noticed that like at a red light i have to slam on the break to keep the car from wanting to push me through the light...i can just cruse at 30 with it in gear and not touch the gas pedal...i asked about it and he said after i get the stall it will quit doing that...it just pushes really hard, if i put it in gear it wants to take off... idles at 600rpm
JimsWS6's Avatar
With full bolt on's, I would get 30.5? tops out. With just the addition of my cam I went down to 28
Old 02-10-2009, 05:40 PM
bballr4567's Avatar
A stall WILL NOT help the car pushing or idling rough. That is a sign that its not tuned well. Whenever you get a good tune the car wont surge as much and be much much easier to drive.
https://ls1tech.com/forums/automatic...questions.html
If the car is dying at the idle then its not tuned well. A stall does NOTHING at idle as its not even working aside from just pumping fluid.
Old 02-10-2009, 06:20 PM
Transam1's Avatar
Do i need a stall with a cam???
Usually. Most people tune the car for the cam which involves raising the idle speed on the car. Without a stall, you will have to just stand on the brakes to keep the car still because the engine is now idleing at 800rpm. Also, a bigger cam shifts the power band of the car higher, a stall enables you to jump into the cam's powerband faster so youll be faster.
that was on the link that you posted...and it seems to me like if the car wasnt pushing me then it wouldnt die...when i put it in gear (that only happens like twice a week..)
Old 02-10-2009, 06:26 PM
bballr4567's Avatar
Yes at IDLE. You are having trouble with it coasting at 30 MPH without ANY input of the throttle. Thats a HUGE problem.
THAT is what a stall is for.
Oh well, Im trying to help you understand that the tune is all jacked up and that is the reason you are having so many troubles with it. People have put in FAR bigger cams with the stock stall and have virtually no driveability problems with a good tune.
Old 02-11-2009, 03:46 AM
BobDoLe's Avatar
well with a STALL on stock heads/cam my gas mileage is about the same as yours...
highway, with the converter locked and cruising along about 90mph, i can get as much as 22mpg.
Old 02-12-2009, 08:35 AM
Mike@HSW's Avatar
Thats not necessarily true. I have TEA TFS 215's, bigger cam, vic jr, NW90 and elbow, M6 and 3.90 gears. Based on the numbers in your sig i put out 55 more hp and i still got 17-20 mpg. Not trying to show you up, but just saying it is possible to mod that much and still get decent gas milage. I dont honestly give a **** about gas milage, but i was really impressed with that.
Old 02-18-2009, 05:47 PM
No kidding? I'm lucky to get 165 miles per tank. Unless my math's wrong, I put in around 13.5 gallons per refill and that averages 12-14, correct?
Old 02-20-2009, 07:26 PM
Am I the only one who gets a measly 165+- miles per tank?
Old 02-20-2009, 08:26 PM
SOMbitch's Avatar
Mods in sig hiway I get 250 +/- a bit on about 13.5 gal. That is always getting on it a couple times cause I just can't help myself 335 +/- dead stock........
Old 02-21-2009, 06:17 AM
I don't drive mine too hard, I get on it here and there but still, 165 is average for me.
