overkill??
Old Apr 12, 2009 | 11:23 PM
NAAllTheWay's Avatar
Default overkill??
okaay so my car is 400 whp with a ls6 intake 222/222 563 563-114 cam with patriot stage 2 ls6 heads......what im thinkin is i want to go to a fast 92/92 and im wondering if that will be overkill for the power im making? will it be soggy down low? anyone who knows or was making simular power who switched to this setup please chime in thanx.....
Old Apr 12, 2009 | 11:25 PM
i want to know that i will pick up around 20 whp without losing any power above 2800 before i spend the cash time and effort so....
Old Apr 12, 2009 | 11:30 PM
hitmanws6's Avatar
i would say it would be just fine for your set up. your h/c combo is big enough to benefit from it
Old Apr 12, 2009 | 11:35 PM
you dont think it will lose any low end tho?
Old Apr 12, 2009 | 11:46 PM
conan's Avatar
https://ls1tech.com/forums/generatio...situation.html
Old Apr 13, 2009 | 01:22 PM
teke184's Avatar
i think it would be worth it, but i guess it depends on what else is done to the car.
you'll def gain power up top, should not lose any down low, although you may not gain much.
i gained good power below 5000rpm on my 400rwhp cam only setup...i was surprised.
but you could also spend the money towards things like suspension and driveline upgrades to handle the power....unless you already have those.
Old Apr 14, 2009 | 12:36 AM
okay thanks again, i think im gonna go with it, let u guys no if it winds back up on the dyno
Old Apr 14, 2009 | 12:51 PM
MelScrilla's Avatar
i would get a bigger cam to take advantage of the ported heads, unless you like real friendly street manners. I like my cars kind of wild.
Old Apr 15, 2009 | 12:14 AM
yea only thing is i have 222 563 now, and i have 59cc heads so they said that the biggest cam that will fit is upper 220's and high 590's so with install im lookin at a grand, anyone think its worth it? how much power to be added?
Old Apr 15, 2009 | 01:23 AM
Detoxx03's Avatar
Yes it will be worth it
Old Apr 15, 2009 | 09:49 AM
teke184's Avatar
20hp should be pretty easy to get
Old Apr 15, 2009 | 10:42 AM
WS6RACING's Avatar
I dont think you will get all that much gain over the LS6 manifold. Not much difference in the flow.
Old Apr 15, 2009 | 10:45 AM
landonew's Avatar
Yes, if it is properly ported. Call tony mamo at AFR. He ported mine and I am very happy with it. Porting makes a big difference IMO, and dyno sheets have proven it on other cars.
EDIT: It should not hurt your low end.
Old Apr 16, 2009 | 07:17 AM
teke184's Avatar
it was enough flow to add 20hp peak, 12ftlbs peak
as well as 5-10hp and torque from 3000+
even a small cam, with the added flow potential of the ported heads he'll def pick up some power.
