first time to the track thought it would be faster
Old 04-18-2009, 05:34 PM
97ta383's Avatar
Default first time to the track thought it would be faster
So i took my car to the track for the first time and the fastest time i got was 13.05 at 107 my 60ft was 2.06 my car is a 02 ws6 with lt, ory, p&p throttle body, msd/ngk, gmmg, 3000 stall, and dyno tune it made 330rwhp and 326rwtq it was like 60 degrees out and my tires were set at 25 psi i launched it at 1200 everytime i launched it higher it spun pretty bad and i could only give it like 70% throttle out or it would spin. any advice on how to improve my times would be great thanks
Old 04-18-2009, 05:53 PM
raysadude's Avatar
that was good enough i think(maybe for the amount of mods you have you expected more), what kind of tires you used?
Old 04-18-2009, 06:05 PM
97ta383's Avatar
i had street tires and i thought it would be faster cause ive seen people run faster with the same mods
Old 04-18-2009, 06:39 PM
blk/slvr02ss's Avatar
Let some more air out of your tires and go from 1000rpm then 100% throttle.Your car should be good for 12.60's on street tires.
Old 04-18-2009, 06:48 PM
TheBlueKnight's Avatar
I've seen lid and catback 2001-2002 f bodies run 12.9-13.0 Maybe you're at a bad elevation?
Old 04-18-2009, 06:59 PM
97ta383's Avatar
im not sure what the elevation is i live in maryland im going to try leting more air out and see if i can drop my 60ft i think thats what is killin my et
demarco313's Avatar
You can improve your time with better tires or do a little with your suspension. I dont know if its just me but seems like ur hp/tq numbers are a a tad low for a 02 ws6 car with the mods you have. Where did you get it dynotuned at? What is your gear ratio? Are you A4 or M6?
Old 04-18-2009, 07:05 PM
Swift_01_z-28's Avatar
I don't know about street tires, I guess it would just depend on what kind. I have a very mild bolt-on car with som kumho 275/40/17s and even launching off of idle, it just wants to sit there in a cloud of smoke. I definitely agree with 12.60s, but I would think you might need some drs, especially with the stall.
Old 04-18-2009, 07:14 PM
Trunion King
bene's Avatar
With street tires and w/o LS6 intake my best run was 12.6 @ 108. With MT ET streets, LS6 intake, 28.8lb injectors and no tune for those two, I ran 12.2 @110.
Old 04-18-2009, 07:54 PM
mook99ta's Avatar
Letting air out of street tires doen't do much, the side walls are way to hard to crinkle and 25 psi is way to low. Try some sticky tires. And the driver mod just joking
Old 04-18-2009, 08:54 PM
Like i said, I guess it just depends on which tires you use. I can't get these kumhos to hook for anything.
Old 04-18-2009, 09:09 PM
97ta383's Avatar
the car was dynoed on a mustang dyno and its an auto it has bfg tires on it i believe they are the same brand the car came with new and it has 3.23 gears 12.20 is really low do you have a stall? Im goin this friday and will try again
Old 04-18-2009, 09:13 PM
MattxFatal's Avatar
Originally Posted by demarco313
Are you A4 or M6?
A4, you must have missed the stall part.
Something is off man.
Exspecially since you are stalled.
Your trap and ET are not where they should be at all, tires or no tires.
-Matt
Old 04-18-2009, 09:20 PM
Trunion King
bene's Avatar
When I had my auto, I was using YANK ST 3500 w/ 3.42 rear.
I dynoed my car a day prior of running it at track and ran 12.2 @ 110 in a 1/4 that following day.
EDIT: And that best run was on stock suspension, 18s on the front and 17s w/ MT ET streets at the back. No weight reduction. Total race weight was 3429 lbs.
Old 04-18-2009, 09:31 PM
97ta383's Avatar
^^ Nice man i need to get some tires!
Old 04-19-2009, 09:05 PM
WnaSty6's Avatar
Default Drag radial much?
dude, i had my car at the track this weekend. it is stock with a lid and cat back on 235 streets, launching at 1200rpms to WOT at the light hooked and ran consistant 2.00 60ft times manually shifting the A4 between 5500 and 6000 rpms. With a good burnout and a well prepped track. i think your stall is too much for street tires, get some drag radials and happy racing.
Old 04-20-2009, 03:47 PM
Shackleford's Avatar
I wouldn't manually shift. It's not good for it and it takes a split-second longer for it to shift.
Old 04-21-2009, 03:10 PM
MattxFatal's Avatar
Exactly.
You can't do it better then the computer.
Leave in third to save the sprag and before the 2-3 shift, move the shifter into 4th to save the overrun clutch.
-Matt
Old 04-21-2009, 03:22 PM
ZGOBYBY's Avatar
It is really interesting what kind of difference you get when you go to the track for the first time and what experience does for you. I like to vary my pressure and see what that does... sometimes 18, 19, sometimes 20. Leave the car in D and brings the RPMs up to the point just before your tires start breaking lose. That is what I do.
Old 04-21-2009, 03:39 PM
97ta383's Avatar
So when im racing i should leave my car in drive? Ive heard people but it in third to keep it from hiting OD put the car never hit OD so i figured drive would be the best im going back this friday hopfully get some better times ive been praticing my launch so i think i will do better
