A4, cam without stall??????
I know I've beat to death the 'more power' question, but I just want to double check this. I know a stall helps get the car into the cams powerband quicker.
SOMbitch has told me in the past I need a stall before a cam as I'm A4, and I don't doubt it. And thank you for all the guidance you've already given me![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Problem I got is, a stall may probably break my transmission, and I really need to avoid that extra expense.
My plans may take a while to compleate, but I know where I'm heading (check sig).
I'm looking for a low end power increase, that will help my acceleration between 20mph - 70mph, (hoping a cam may be my answer).
1. Is the cam stupid without a stall ?
2. Can I pick up some acceleration power with a cam, without a stall?
3. Mabey I'd be better off with 1:85 roller rockers? (The cam install will be a PITA) If the cam will only be a 'bit' better than the rr, I'll avoid the cam install grief
I know a stall would make the cam 10 x better, but I don't want a broken tranny, mabey I'm pissin in the wind considering just a cam.....![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Thanks for all the help
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
how many miles are on the car?
from what i remember 4L60E's are only rated to like 360rwhp from GM. of course there's people pushing 450+ out there, but if you're worried about the stall taking it out you may want to think about what the extra power is gonna do.
driving a cammed/stock stall car is going to be pretty annoying too unless you go with a relatively small cam. if you have plans of doing a trans or stall in the future anyway you might just wanna wait so you can go bigger, or use that money towards a transmission or rebuild down the road.
i'm sure with a mild cam it'd be fine, but anything big will get annoying fast
The only cam you might be able to pull off would be the z06 cam other then that you will need to get a stall. I am in the same situation I would like a big cam for my set-up but do not have the extra funds for the stall so I cant cam it yet or it would be a waste.
Don't put money into things you can't afford to fix or do right. When in doubt, save up money and do it properly, ie: Get the stall, save for a new trans.
Automatics with an aftermarket stall really do well. Putting a cam before that is sort of like not putting your shoes on until you're home from work. Do the stall.
Okay thanks guys.
So I guess a small cam (Z06) wouldn't be worth it??
If say, the cams worth 30hp, and the rr worth 10hp, then I'd do the cam, but I'm guessing a mild cam isn't worth 30hp?
I guess I'll play safe and keep to bolt ons and do the 1:85 roller rockers for a tad more lift, easier install too......
Thanks again
Thanks again
Okay thanks guys.
(If say the cams worth 30hp, and the rr worth 10hp, then I'd do the cam, (but I'm guessing a small cam isn't worth 30hp?))
Thanks again![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Thanks again
I doubt you would get 30 more hp with the z06 cam unless you get a tune along with it. As far as 1.85 rockers they are a waste and you will be probably be pulling them off in the future when you do decide to go with a bigger cam.
^^^^Yup dont spend 5 or 600 dollars on rockers, when you get a bigger cam you will want to go back to stock ratio. If anything do bolt ons. Use the money you were going to put into a cam and buy your headers, you can get a used set on here cheap. If you keep the cats you wont really need a tune, it would help but you dont need it. That should provide a noticable difference, and get the best power when you stall and cam it.
i have the LS6 cam and now wish i went slightly bigger. plenty of sponcors on this board could give you good recommendations w stock stall. when i was looking i called lunati and told them i wanted good street manors with stock stall and they said 221/221 560 lift on 115 lsa. (i should have listened!) the board will probably say 224/224 565 lift on 114 lsa. thats probably max to have a civilized idle for stock stall. goodluck cheers! ps always upgrade your springs for a bigger cam
A stall done right won't hurt your tranny. Put a 25-30lb. cooler and and shift kit in it and you will be fine unless you already have a problem. I have 92k on a stock internal tranny right now. 42k of that with a stall.
My best advice to you is make sure to get a QUALITY stall![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
I hope I didn't just jinx myself
I am taking off on a 1200 mile trip tomorrow
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
If you cannot do the the cam and stall at the same time, I would do the stall first. It will not automatically break your tranny. That is a silly notion. It might wear out your rear tires faster, however. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Heat is the enemy of automatic trannies. When you do the torque converter install be sure to also install a good tranny cooler. You might also look into a finned aluminum pan like a TCI. Their pan for 4L60E sheds heat quicker than a stock pan and it carries an added 2 qt. capacity which also makes your tranny fluid more resistent to heating up.
My 4L60E in the track car with a 3600 stall runs no hotter than stock due to a good cooler and TCI pan.
I recently posted a poll, 'will the 4l60e take a stall?', and 40% think a stall will kill my tranny, or possably will. 60% say I'll be fine with stock tranny. NOT great % if you ask me.....
A stall sounds great, but I don't want to keep dumping $$ into my car (too many other expenses), and I know I could save for longer, but rebuilding my tranny is a expense I don't want to have to risk.
Okay, I had a look at the cheatr cam, but it looks more like a cam for stock mainfolds and n20.....
I don't fully understand cam terminoligy (it's huge), but this sounds like a good recommendation, and I'll look more into it. When it's time for a cam I'll ask the site sponsers for advise too....
Agreed, not the best option, but I'm only considering it if a cam is out of the question, and they've got to be worth 10-15 hp....
I'll look into the gm hot cam also.
After looking around on here, there are a few people running cams on stock stall.
It is more a question of what I'm prepared to spend, than what can I afford....., you can see my planned budget, and probably up to an extra $1000 on top of my planed mods
So what sort of gains could I hope for from a cam that is designed for a stock stall?????
Would 224/224 565 lift on 114 lsa still be civilized idle for stock stall?
1200 miles sounds like a great road trip SOMbitch![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Thanks for taking the time to help
No, that's a stupid idea. The roller rockers aren't worth a ****. They offer little gain and cost as much as a cam.
