Asp Pulley Problems!
Old Nov 22, 2003 | 10:13 PM
IneedSleep's Avatar
Unhappy Asp Pulley Problems!
Hey guys,
HELP! ack, I installed my ASP underdrive pulley on my car about 2 weeks ago, (01 A4) everything runs great, no noises from belts..etc
but it seems that my car is leaking oil from where i installed the pulley, its comming through the seal it seems.. its not a TON, just drips here and there..
ive leaked out about 1/4 quart in the last 2 weeks
does anyone know a fix for this?
is the pulley defective?
seal broken?
Please help,
Thanks
Old Nov 22, 2003 | 10:51 PM
jrp's Avatar
jrp
SN95 Director
could be a worn/broken crank seal. i assume all you did was take the stock pulley off and install the new one right. you didnt take the timing cover off or anything? if you did take off you should of replaced the seal.
Old Nov 22, 2003 | 11:35 PM
IneedSleep's Avatar
Nope, I just took off the stock pulley and replaced it with the ASP pulley
I took it to a shop today and the guy said its too small and I need to install the stock pulley
Old Nov 23, 2003 | 12:05 AM
jrp's Avatar
jrp
SN95 Director
you did get an F-BODY asp pulley right? the vette and fbody pulley are different. you got the shorted belts also right?
Old Nov 23, 2003 | 12:53 AM
INMY01TA's Avatar
Just need to change the seal. Keep the pulley.
Old Nov 23, 2003 | 09:34 AM
IneedSleep's Avatar
Yeh, I ordered the pulley from TSP,
Where do i get the seal? does anyone know a part #?
Old Nov 23, 2003 | 11:48 AM
Kevyn's Avatar
I got mine from Thunder racing. Part number 12561244.
Old Nov 23, 2003 | 12:08 PM
LS1swap's Avatar
You really should replace it anytime you remove the pulley. especially if it has been on a while. Its part number is 12561244.
Old Nov 23, 2003 | 12:12 PM
LS1swap's Avatar
BTW the threads for removing the ASP are SAE not metric..... something like 5/16 24 but i am not possitive on that other than they are not metric.
Old Nov 23, 2003 | 02:27 PM
Smoke_Ford's Avatar
Time to replace the front main seal.
Old Nov 24, 2003 | 02:52 AM
jaberwaki's Avatar
along with changeing the seal .... dont ever go back to that shop....
that guy know d!ck about f-body's....
also did you change the pulley bolt too or reuse the one you have???
