Mid-Low 11's..how tough is it?
Hi Guys. I have been a member here for a while, but don't own an LSx powered vehicle. For the last 10 years or so, I have been into turbo Buicks, but have recently sold mine, and am looking for a newer, better supported platform. I know with the Buicks, once you have a clean running STOCK car, for about $3-5k, you can have a reliable, mid/low 11 sec ride. By reliable I mean a car that can run 11.30's all day and not blow the rear end or trans out of it. Some say it can be done for even less, but that's up for debate.
Anyway, what is the rough cost for a 99-02 Z28 to run those same numbers starting with a clean running stock, or nearly stock car? I know it is always cheaper to start with a modified car, but I would rather know what is really in the car rather than take someones word for it. Thanks.
Get the newest, lowest mile car you can for your price range.
Easiest way to go fast, get an automatic.
My car runs LOW, LOW 11s all day long with headers, gears, stall, drag radials and a small shot of nitrous.
biggest thing that these cars need is a rear end...if you go auto its not AS big of a deal that's for sure.
very easy...a cam only bolt on stall'd auto will go AT LEAST mid to low 11's all day w/ the right suspension easily.
Chad
Chad
Its so easy, nobody on here really cares if you run 11's in an LS1, its the norm for a mildly moded LS1. if your not in the 9's its nothing special. Thats just how good these engines are.
I share your views on buying a stock, or near stock car, and then modding it yourself. When I bought my car in early 2006, it only had 32,000 miles, and was totally stock, save for some crappy, cheap, aftermarket muffler. When I mod a car, I want only the highest quality parts on the car, so it is important to know what you're starting with.
Yank SS3600
3.73 (but I recently swapped to a 3.50 gear)
100 got me to 11.100 on 3.73s
125 got me 11.04 on 3.50s(and Moser 9" and 6pt rollbar), but the bottle went empty on that pass.hah. On a night with good weather, I have no doubt that the car will be a 10.999 or better on a 125 shot.
There is no doubt, these cars will fly, but being that they are getting near 25 years old now, it's getting real hard to find one that isn't ragged or rusted. Not to mention Buick only made the intercooled cars for 2 years. I'm looking for something a little newer and with a larger aftermarket.
Don't limit yourself to your local area.
I took a bus from Memphis, TN to Savannah, GA to get my 2002 Z28. A friend and I took a plane to Atlanta to get his 1998 Z28.
Deals are all over the place, and sometimes the price of a one-way plane ticket is well worth the savings you might find.
mid to low 11's.....full bolt ons, 373 or higher gear, 3600 stall or higher, cam/heads.....depending on what size cam and what heads, should put you 11.1-11.5....cost well, thats really open to what brand parts you go with and if you have to pay for labor or not....headers-400-900 catback-350-500 intake-...used ls6-250 all the way up to 1400 if u go with a ported 92/92...gear 150-450 depending on if u get the whole kit wich isnt completely neccesary...stall..350-850.....heads..port your own maybe 200 on the low side up to a set if cream of the crop heads 2500...cams are all around 400..need pushrods...and u need springs if you just port your own heads, gaskets you also need so you lookin at spending....2500-7200 on parts if my math is correct, labor should be around 2500 on the low side and 4000 on the high end, most likely around 3k, just depends on what local shops charge...so anywhere between 2500-11k depending on what you want to do.
to run mid to low 11's...big weight reduction, about every 100lbs is a tenth...figure bolt ons if u have gear stall, can get you to low 12's u wanna drop a good 500 lbs if u wanna run low 11's with bolt ons
