Anti-Seize materials?
i'm needing to buy some anti-seize, and i've come across 3 different kinds...
silver, zinc, and nickel.... what are the differences? is one better? is there a certain one i need for bolts in the engine and such?
i bought one that didnt specify what was in it, checked the model # on the site, and it says it's a blend of copper, aluminum, and graphite lubes.... should i go back and get a diff one? #80078
copper/aluminum reaction ( Google that for some reading).
In an automotive environment and where they are used in a compound, I've no knowledge.
But in construction, the two metals are very destructive ( the aluminum is always destroyed).
Permatex says it is OK for spark plugs in aluminum heads!!
In construction the mixing of copper and aluminum creates galvanic action/corrosion
Permatex® Copper Anti-Seize Lubricant
A premium quality copper anti-seize and thread lubricant that may be used to prevent seizing, corrosion and galling where high temperature conditions exist. Contains a high percentage of micro-fine copper flakes in a semi-synthetic grease carrier and is fortified with high quality rust and corrosion inhibitors. Temperature range: -30°F to 1800°F (-34°C to 982°C). Provides good electrical conductivity. Meets Mil Spec #907E.
Suggested Applications: Spark plug threads installed in aluminum, exhaust manifold bolts, engine bolts, oxygen sensors, knock sensors, thermostat housing bolts, fuel filter fittings, and battery cable connections
