What do I need for a Header install?
Looking to install some long tubes in my '98 Camaro
What should I bring to my friend's shop so the job will go smoothly?
I've got the headers, about to pick up a Y pipe, and i've got oxy sensors w/ the longer pigtails
Do I need a reducer or something to connect the y pipe to the stock cat back?
Get Corvette o2's instead. They are longer. I've never had any o2's last more than a month with the extensions. Like above GET THE STOCK MANIFOLD GASKETS!!! They by far work the best.
Don't forget to bring your patience.
just got done installing mine. like optimus prime said above, you need to be patient. fitting those headers in will be like a puzzle. there was a couple heat shields i had to take off (7mm socket) and the steering link. idk if thats what it is called but its just 2 bolts, and a pry bar.
i keep hearing to get the gm stock gaskets. i used the ones pacesetter sent.
this may be important: i have a 2000 so i idk if it will be diffrent with the 98s. but on the pass. side, i couldnt remove the very bottom bolt that held the egr hose on the manifold. i tried every combonation of extensions at every angle and coulded get it loose. when i got fed up with it i got the dremel out and cut it off, haha.
moral of the story: plan ahead. if you want to delete the egr then do it durring the install. that way you can save $10 on the headers by getting the ones that dont have a place for the egr (i got pacesetters from texas speed). and you wont have to make plates to block off the egr.
has anyone else had the same problem?
The higher you can lift the car off the ground the better...if your jack reaches the maximum height and you need the car higher use a block of wood on the arm. Make sure you also have sum floor jacks(Duh) and like they said above alot of patience. I also disconnected the steering linkage. As far as the exhaust goes if you picked up a aftermarket y pipe(Off-Road Y-pipe) and say its 3" you will need some couplets to connect the y pipe to your headers. i dont remember what the I.D. or o.D. is im assuming either 3 1/4 O.D. if your ypipe is 3 inch. I couldnt find any so i opened up the y pipe a little bit in the ends and got the headers to slide in about 2 inches then i tack welded the som bitches and used U-Clamps on em...the clamps seemed to hold up but as soon as i fired up the car the dam y pipe would fall off. Havent had any problems at all and my exhaust is the 4" mufflex...no exhaust leaks and no exhaust bangiing issues either...im at stock ride height.
Ive heard a lot of people change the motor mounts while theyre in there. What are the specific problems with the stock ones and where is the best place to get some new ones?
Theres no real problems with them. its just that after a while they start to get old and lose their strength. when that happens, the motor sags a little bit or it won't be able to handle high rpms. When this happens, the ORY starts to hit stuff.
Also, if you decide to wait until later to install new mounts they are gonna be a pain in the *** to install with longtubes on because they get in the way.
If you don't want to pay for poly mounts, I would go OEM to be safe.
EDIT: As far as where to get some, I would imagine Kentucky Speed would have them. I order stuff from them. Great ppl.
I'm not sure what a set of OEM's go for, but the Prothane Poly Motor Mounts on my car were $49.95 from Byunspeed.com. Fifty dollars won't break the bank and if you're gonna go thru the trouble of doing it, you may as well upgrade rather than simply replace.
Good luck.
This is very good advice.
Good luck.
Good luck.
EDIT: Since noone else mentioned it I will....Jack Daniels needs to be brought, hes my right hand man.
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
PS, another thing you will need for the install is the double "B".... beer and bandaids, have fun and good luck
