Hole in brake line
Ok so i changed my plugs today and when i pulled off my blower inlet tube i saw a groove in the top of the line that goes to the right rear brake. The dealership said it would be 330$ to replace the line and naturaly i said f**k that. it is only a pin hole but enough to leak fluid, do you guys know of any way i could patch it or seal it someway??? any help would be great.
Hmmm...I hear the ducktape gods calling...great time to save up for a whole new brake kit...Baer sounds nice to me...good luck
Wes
Wes
Originally Posted by onebadz
Hmmm...I hear the ducktape gods calling...I would do it until I got a brake upgrade...great time to save up for a whole new brake kit...Baer sounds nice to me...good luck
Wes
Wes
Hey buddy it was sarcastic...chill out
Wes
Wes
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Originally Posted by wrencher
I would just cut the section out flare both ends install union & put it back together & bleed.
Hey thank you guys for the help, right now i have some JB weld on it just so i can to work but im going to get some tubing and fix that section, Now if i just go to kragen and tell them what i need to do can they get me the tubing and the fittings, flaring tool, and tube cutter. Is this done often or rarely.
If you tell them you need a double flare tool kit they should know exactly what you are talking about. The tubing cutter should be a easy too. It's done quite a bit so no worries. If you are worried about it I would take it to a good shop and have them do it, they can do it probiably within an hour. Should be no more than a few hours worth of work and about $35 worth of tools and parts if you do it yourself. Like I said get an extra piece of tube and practce making the flares you if decide to do it yourself. Just some helpful advise. If I was local to you I would offer a hand but you know
JB weld on a brake line........................................... Brakes are not a thing to say........Ill fix them when I have time, or money. If your brakes fail and you hit a car or a pedestrian or a kid running out into the street. You will have all the time to think about what you should have done when your locked up, and money wont be an issue either. Its an easy fix, just do it unless you work 24 hour shifts you have the time . Or call in I had to call in this week to rebuild my trans didnt want to but didnt have a choice. If you dont have time drop it off at a shop, and get it fixed. driveing with unsafe brakes is like playing russian rollette with other peoples lifes.
Agreed. Do not drive the car again until you get this fixed. I have had my foot go right to the floor in another car when I was applying the breaks. Talk about a puckering experience!!! I know left a suction mark on the seat!!!
All because of a pin hole in the break line.
Thank God I was in a parking lot and not going very fast. I had to Emergency break and shift to low gears really fast to prevent from hitting a parked car.
Please, please. Do not drive the car again until you get the lines fixed.
