Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Transmission Guides
- Camaro How to Change Rear Differential Fluid<br>Step by step instructions for do-it-yourself repairs.
Rear Differential Fluid Change Interval
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I checked my owner's manual to see how often the rear differential fluid should be changed but I only found change intervals for the transmission fluid when we have an automatic transmission. Now I have two questions!
- How often should we change the rear differential fluid?
- How often should we change the transmission fluid when we have a manual transmission?
If you have the Auburn unit it is 6000-7500 miles. I couldn't find the schedule either but I did my first change at 5000 miles (stock rear axle) and will repeat it every 10K.
Manual tranny: if it were mine I would change it every 10K as well, depending on how you drive it.
Brad
Brad
Originally Posted by 98Z-6Speed
How hard is it to perform that? Does anyone know of an online "how to" or can you just explain it if you don't mind please? I drive mine pretty hard so I would like to do it.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Originally Posted by IrateTA
Good question... I didn't realize it had to be changed that often... ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
It doesn't "have to" be changed that much. From memory, F-body owners manuals used to say change it once after a break-in of 7500 miles (from memory, could be off a bit) and then just leave it.
However, that is for "normal" people. To GM, "normal" people aren't adding power mods or going to the track.
I change the diff fluid in my "track cars" once a year.
For the new guys like me wanting to know how to change the rear diff fluid, here is a link I found in the pinned "how to" thread on this board. This board is such a great resource.
http://www.bfranker.badz28.com/fbody/lubeoil.htm
The manual states 7500 mile intervals with standard oil. After the first 7500 miles I started putting full synthetic in, so I will change every 10k now. Like everyone says, its how you drive it......................
STF Veteran
Originally Posted by S2002S
For the differential, you can buy a cover ($30) with a drain plug to make the oil change task trivial.
The reason there isn't a drain plug in the rear,is it don't have to be changed.I have been driving for 53 years and have never changed rear end fluid. I have never had a problem either. The same goes for the stick trans.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by Weezzer
Thats strange - No where in my 02 Helms manual or the manual that came with my T/A does it say anything about ever changing the differential fluid, tho I did change it about 7500.
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
Thanks for all of the good replies so far. All of them have been valuable.
I read the information at that web page. It looks good. If/when I change it I'll have a print out of that web page with me in the garage. I also found good information at Install University. The direct hyperlink to their "how to" instructions for changing the transmission fluid or rear differential fluid is TA Performance Rear Differential Cover/Fluid Install. I'll print this too!
Yes, I saw that at SLP and it is part number 65003. If we should be changing our rear differential fluid regularly then this should be a great thing to have. I was going to ask about this in another thread. I'm curious if draining and refilling is good enough - or is it really better to take the cover off, drain, wipe everything up really good, and put the cover back on with a new gasket and some RTV. After all when we change the motor oil we simply do a drain and refill - we don't drop the oil pan, wipe everything up really good, and put the cover back on with a new gasket and some RTV. So I'd guess that draining is good enough and this cover with the drain bolt is good enough.
I could not find it in my 2002 owner's manual either. Maybe it is in the owner's manual from other years or from the Camaro? I don't have the FSMs yet. The Pontiac Owner Center only has the following information regarding this area and they say to do it monthly:
One of my other cars is a 1996 Impala SS with the 4L60E automatic transmission and a rear differential. From memory I think the owner's manual told me to change the rear differential fluid at 1 year or 7,500 miles, whichever came first, and then not to do it again. This weekend I'll check that car's manual and see what it says...
Check the transaxle fluid level; add if needed.
Originally Posted by lerajie
Read the owners manual. I believe the interval is in there.
