After header install?
well i got my headers on today and it sounds good but i got a few questions, I did header, ory, and egr air pump delete so i was expecting backfire and maybe a few codes to show thats normal without a tune right? also i feel something rubbing kinda feels likes i-pipe on driveshaft, anything else i need to do or look for? anyone else had same after math problems? thanks guys
p.s pacestters slid right in with no problems total of 5 hrs for everything. thanks for info
Codes will pop up after first good drive. I don't know about egr, but you'll notice no ill affects without a.i.r.
You might want to look into that rubbing issue. Maybe get under and see if you can shake things with your hands.
Ok another question, I am getting tuned tues, since install i have metioned above, i have had a few codes (post #4) that im sure can be cleared or bypassed by my tuner, i noticed today a little lack of power and what seems to a miss are these also common symptoms of my install? and other than motor mounts has anyone came up with a way to stop the y-pipe from beating the **** out of the floor pan? thanks again guys
I noticed that my car wasent running right after my header/Y pipe install on my z-28. Part was the shitty header gasket it came with blew right away but the second part was I did not remove my spark plugs when i put my headers in and the header bumping the spark plug made it/them break, after fixing both problems the car ran great! On to your other problem, I know I had the same thing with my y pipe but we loosened it up and wiggled it around and tightened it back up so it wouldnt hit, If it that doesnt work some guys use poly exhaust mounts. Hope it helps, peace
~ReD~
~ReD~
Thanks for info, Was yours race style headers or did you also do egr delete? I ran out of time and didnt change plugs either but my scanner isnt showing any cylinder misfires. I guess i will have to try to do something with the y-pipe thats annoying as ****, thanks again
