Best cam and spring kit!... I can get an exchanged
I originally bought The Following...
Comp Cams
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 800-5,800
Intake Duration at 050 inch Lift 206
Exhaust Duration at 050 inch Lift 212
Duration at 050 inch Lift 206 int./212 exh.
Advertised Intake Duration 259
Advertised Exhaust Duration 265
Advertised Duration 259 int./265 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.515 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.522 in.
Valve Lift with Factory Rocker Arm Ratio 0.515 int./0.522 exh.
Lobe Separation (degrees) 112
Camshaft Gear Attachment 3-bolt
Computer-Controlled Compatible Yes
Grind Number XR259HR
Valve Springs Required Yes
VALVE SPRING KIT AS FOLLOWS...
Brand COMP Cams
Manufacturer's Part Number 26915CS-KIT
Part Type Valve Spring and Retainer Kits
Product Line COMP Cams High Performance Valve Spring Kits
Summit Racing Part Number CCA-26915CS-KIT
UPC 036584225478
Number of Springs Per Valve Single
Outside Diameter of Outer Spring (in) 1.290 in.
Damper Spring Included No
Spring Rate (lbs/in) 313 lbs./in.
Inside Diameter of Outer Spring (in) 0.650 in.
Valve Spring Style Beehive
Coated No
Retainers Included Yes
Retainer Material Steel
Locks Included Yes
Lock Style 7 degree
Lock Groove Quantity 1-groove
Lock Material Hardened steel
WHICH is not going to give me what i was expecting... (high HP gains, Agressive sound, long trips on ocassion, And respectable 1/4 mile times...
Therefore, I come to you guys to give me your best suggestion In CAM AND SPRING kit possible, without having to Change any of the Internal Components.
Already seen good cam options from you guys, but dont want to make an xpensive mistake on both item selections.
Comp Cams
Brand COMP Cams
UPC 036584225478
Coated No
Locks Included Yes
Lock Style 7 degree
some f-bodies ,01-02 got ls6 short blocks,241 heads..you will need better push rods also.start by going to the TSP website and look at cam pkgs.thunder racing has a great priced cam pkg also.you can buy a valve spring compressor and change the springs in car.go to ls1howto.com for instructions and pics.I recomend a EPS cam and some pac 1518 springs(beehive) and harden push rod.or you can look at comp LSr cam.
comp ovate wire springs
cam 228/228 581/581 112
chromoly pushrods
double roller timing chain
high flow oil pump
enjoy the cam for awhile, than when funds allow, a 3600 stall.
chromoly pushrods
high flow oil pump
make sure its 228 at .050 lift...
yeah the 228 cam is an excellent cam for a fun weekend driving A4 fbody.
if your feeling more aggressive look around a 228/232 cam. remember on the simple side of things, higher the numbers and lower the lsa like 112-110 the car will idle rougher, and not be as street friendly.
I would do a 228 on a 112.
call geoff at eps or contact pat g on this board and theyll set you up with a cam that will suit you. sounding tough and being tough are two different things. do you want to go fast or chop so hard that the wheels fall off? your choice.... id look up some cams and sounds on youtube first. i personally like my eps 230/234 on a 111lsa it chops pretty hard and drives great with great power between 5000-6200 rpms.
Well both of course, the point of mods IMO is to get great 1/4 mile times and the hp out of the set up, but it wouldn't hurt for the engine to sound as good as it runs... Right?
I can't do heads and intake right now, just got to get the best outcome from the the stock Ls1 components. I never imagine picking out a cam was so much work and headaches!!!
