NEWBIE: Just picked up the Bird yesterday....help
Sold my '79 T/A for my first experience with a 4th gen. 2001 6 spd WS6, 83K. Borla exhaust. Couldn't take the smile off my face on ride home!! til I got back and the check engine light came on and oil change light, car seems to ping a bit under hard accel, seems to run OK and previous owner "never" had an issue with light, any thoughts, haven't scanned codes yet.
also turn signals don't flash, just one DRL stays on, just bought bulbs and have not put in yet but not sure if thats the issue, are the DRL modules problems on these? do these cars have electrical bugs??? guess I should have researched more before buying this car but bought it not using reason, lusted after it! thanks for any help.......
oil change light is usually nothing. You can reset it by holding the trip meter stock thing lol. i dont remember exactly how, but its in the owners manual. After so many miles it will come on again. As far as the SES light i have no clue could be several things.
BTW if your talking about the your turn signals the best way i find to change those are to get under the car. Theres a plastic cover below the turn signal on the bottom of the car. Just take out 2 bolts, i think there 11mm and the plastic flap will fold down allowing you plenty of room to get to it.![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I know this seems kind of obvious, but i didnt know this until i started searching around for a better way to get to the turn signals other then stick my hand through the big hole beneath the turn signal lol.
Thanks everyone , I just replaced the bulb and now both parking lights work but no DRL's, and no turn signals in the front, rears light up but don't flash, front does nothing, except parking lights work fine.....grrrrr
and pulled battery cables but check engine light still on....
for your engine light, take the trans am to your local chevy dealership. ask them if they can hook up their "tech2" to scan for codes and clear them out. For your flasher problems, u might want to cut out both front turn signals, and buy aftermarket. i had to do the same. water likes to get in their and corrode the socket. and also replace fuses if needed. the enginline might be triggerd by your o2 sensors going bad. thats about when mine did.
This is Gettin fun.... Went to autozone to have them scan codes, when they did it wouldn't even power reader, they said obd port was disconnected or bad fuse? Why would port be disconnected, ses light still on, now what. Also messed with front signals and nothing, don't even light up with hazards. Just parking Lites work. Buts she's so beautiful I'm try not to loose it.
I got my baby z28 2 months ago, knew about a couple problems with it..
Just spent $400 on new front tires today....
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
next is brakes...dont know if i need rotors or pads...im pretty sure its both haha.
After that i got 3 codes for secondary air injection fault..
should have it all cleaned up by the end of the summer and in perfect condition for next summer.
You will soon learn young grasshopper:
4th Gen LS1= MONEYPIT. Owning one is like having a hot *** wife that bitches a lot. When you can get her to shut the **** up and do her job, she's worth it.
Even if it ain't broke, you will still find **** to buy for it.
Welcome!
Welcome!
agreed, its just new-used car maintenance that the previous owner wasnt interested in..
Just spent $400 on new front tires today....![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
"obd2 is a fuse...most likely the stereo fuse or cig lighter fuse"
I'm definitely gonna check that after work!! that latest issue took alot of my sleep last night! thanks everyone, really appreciate..... drove it around yesterday a bit and its a beast! luv it but think I may be needing alot of help from this forum, but I hope not!!!! any other tips please let me know, gotta really start going through this site. heres a few more pics.
OP, I had very similar problems with my camaro when I bought it. Front turn signals wouldn't work, but the parking lights worked fine. Rear blinkers would light up but wouldn't flash. The problem was the flasher relay which is under the steering column. Pull off the panel under the steering column and I believe it is off to the right, someone can correct me if I'm wrong. The relay is round and silver, easy to get to and change, and I don't think it was more than $15. This would probably be worth a try for you.
Just replaced turn signal flasher, now they blink but only the taillights,guess I'm gonna try replacing front bulb sockets, anyone know the part number? Autozone or napa, Thanks again
At 83k its time for some routine maintenance IMO. I would start with plugs, wires, fuel and air filters, and a set of 02s. Look into a coolant flush, transmission fluid and filter swap, and a rear end gear oil swap should keep you busy for a while and you might learn some about your new car in the process.
