best cam for shorties ,00 m6
ok guys so im in a dilemma i have an ls6 intake 799 heads and i have pacesetter shorties , i hear nothing but good things about the tr224/224 114 lsa cam , but also good things about the cheaTR cam 218/230 118 lsa for stock manifolds , since i have shorties what in your guys opinion would be the best. im trying to get as close to 400hp as possible thanks !!!!
I had a ls1 with with 243 heads and shorties in a 04 GTO with a predator cam 224/231 577/588 and it made the same hp with shorties and then long tubes.If interested I can get you more info on the cam.
IMO there really isn't a BEST cam for shorty headers, the key is to staying with a small enough cam to where the exhaust isn't restrictive. And with the above example the GTO exhaust is different then F bodies. So although a 224 cam will work with shorties you would probable be leaving a few ponies on the table without LT's
so i better just ask the shop who is going to do my tune then , they have tons of experience with lsx engines , Fbodyjunkie06 so you think the cheaTR will be my best option ?? and still pass smog ?
If the cheaTR has 12 more exhaust duration to help with the manifold bottle-
neck, and shorties are slightly better (5-7hp), I'd guess perhaps only 8 deg's
more would help the cylinder head's 70% Ex. to In. flow ratio. EPS 218/226
when tuned will sound and act stock yet still pass smog
looks like i found the cam !!!!! eps 222/226 115+3 same guy here locally in Sacramento is running same cam, and went to same tuner made 365hp on stock manifolds and just cat back thanks for all the advice guys
One of the major questions in the healthcare industry is whether major insurance companies
are going to hop on the meaningful use train as well.
Best cam for shorties ,00 m6
IMO there really isn't a BEST cam for shorty headers, the key is to staying with a small enough cam to where the exhaust isn't restrictive. I personaly advice all to go for your types of car insurance, also with the above example the GTO exhaust is different then F bodies. So although a 224 cam will work with shorties you would probable be leaving a few ponies on the table without LT's.
