Best stall for M6
I got a 2000 SS camaro m6 and was wondering what kind of stall is gonna work out best for the m6. Also getting a 9" soon, 3:90s or 4:10s?
1 Post
^ Autos do have stalls
(know you ment 6 speeds thou)
OP i'd throw 4.10 or higher in a 9, specially since you have a M6, there's quite a bit of info on the sight here about all that, a lot of good stuff in the stickies.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
LS1Tech Administrator
Received 1,687 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
You could toss the stall converter in the trunk of your M6 car, the added weight might help with traction. That being the case, you should get the heaviest stall possibile. This is the only benefit you will ever seen from a stall converter with your M6 car.
Also, nobody makes a "4:10" or "3:90" gear, as those would be very undesireable ratios. You want to get a 4.10:1 (4.10) or 3.90:1 (3.90) gear.
