Cleaning fuel injectors
I want to clean my fuel injectors but I'm just making sure what brand to use is there a specific brand to use on my 1999 z28 or does it not matter what brand to use like stp fuel injector cleaner? Thanks ls1tech
LS1Tech Administrator
Received 1,787 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If you just want to dump something in the tank for a minor cleaning, I've had great luck with Red Line SI-1. If they are really bad, they may need a bench cleaning.
Does anyone know a good method to clean out fuel injectors when they are out? I have a pair I bought USED and I would like to clean them out... And if I have to send them into a shop how much does it usually cost?
It depends on how dirty they are. If a in tank cleaner is not enough I have had good luck with using an Autovac cleaning system found at some auto repair shops which runs a closed loop through your fuel system for a period of time with cleaners and I think a big step above putting something in the tank but less than removing them for a cleaning. I use Techron on a regular basis when I can but it on sale 2 for 1 to help keep them from getting too bad in the first place. I also ran just a bottle of Techron through one of my motorcycles I had left out all winter due to a surgery and it has 4 carbs. One tank of that and it was idling better than ever and did not need the choke on as long during warm up. If that is not enough then many people use the Seafoam.
http://fuelinjectorconnection.com/sh...php?groupid=79
They're a sponsor and seemed really great when I inquired about cleaning & re-sizing injectors.
