Entertain me this faster ls1 than mine
Ok here is the story my friend has a 98 z28 mine is an 01 z28 his cars first and second gear feel extremely good and his car pushes you back by berley tapping the gas so his car feels like a beast driven around both automatics
Mine feels like a slouch but if we race my car beats him everytime and my car feels more powerful in WOT than his
My question is when I drove his car it was fun because i felt all the power everywhere and mine only when i floor it
whi is this?
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
jk lol
I know when I bought my 98 that it shifted hard, the tranny was slipping or something but would shift "hard" because of it and jerk you back... plus it was bone stock
prior to my 98 I owned a 01 white z28 and it had half the miles and zero noise when I went over speed bumps (more refined) and yes now that i think of it, it didnt bang the gears or feel like my 98 does... But I have time slips from irwindale 1/8 mile and guess what, it was a tad quicker..
It's not about how the car feels, it's what number it puts down.. unless your all about "feel"
if thats a case then get a cam for it and stall and you'll be all set and very happy...
His 98 will have a smaller throttle body cam on it vs ur 01 so 1/4 peddle on urs is more like 1/2 peddle on his, could one thing i have an 00 and switched to a bbk tb and uses the smaller cam so after i got the right throttle cable alittle throttle feels like more, i have more power too cause of the intake/tb but i can feel a throttle feel diff too
If u have a higher stall vs his stock stall urs will seem shitty unless u wot cause the stalls basically slipping till then, i have a truck with 3600 stall and its slow as **** till u get on it then it pulls like no other
Lot of stock differences between those two cars, what are the mods on each?
Edit: saw you said stall in your sig, but your post says you believe you have a stall? How do you not know? But yes this would explain the difference, stock stall is gonna have better low speed blip throttle feel. My 3600 with just a little throttle to pass feels slow as ****, put the peddle down and its a different story.
LS1Tech Administrator
Received 1,756 Likes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Your sig lists all this stuff:
...but you don't mention any mods on your friend's car. Is his stock? If so, I would certainly expect yours to be faster.
If you still have the stock tune with the headers, it's possibile that your A/F ratio is not ideal, and this could be causing a bit of a soggy part throttle feel. It would also be holding back your potential WOT power.
Your friend's car might also have a different gear than yours. There were two optional gear ratios for these cars with an auto, plus his may have been changed since you haven't mentioned if his car is modified or not. On cars with stock stalls, there is a performance advantage to higher numeric gear ratios, in addition to a change in the road feel of the car. Once you have a 3500+ stall, gears won't do much for performance at WOT but they definitely change the way the car feels at part throttle with a stall.
And lastly, as someone mentioned above, if you DO have a stall and if his is stock, then I would expect your part throttle feel to be more "loose" while his is more "tight". And I would also expect yours to be faster at WOT because of the stall, assuming his is stock. So this could definitely explain the difference.
Someone also metioned the throttle body cam size, and this is correct. Your '01 car takes more pedal input to open the throttle than his '98 does, so it will feel like you're giving it more pedal to get to the same rpm. This effect will be further exaggerated if you do in fact have a higher stall.
It's not a matter of refinement, the underpinnings of these cars didn't change at all between '98 and '02. Things like this come down to tires/suspension and overall wear on the car. My '98 has much better road feel, makes no noise and generally "feels" better than my '02....but that is because my '98 has 16k miles and my '02 has 103k.
Also, base models with their original 16x8" wheels will have a smoother feeling ride than their 17x9" counterparts, although the 17x9" cars will definitely handle better when pushed to do so.
Lid, pacesetter headers, qtp y pipe magnaflow custom exhaust, cutout, unknown yank stall
correct sorry for not posting his mods, he has headers not cats, y pipe we both now have 3.23 gears his are stock and I change my rear end to a 3.23 gear one, we have the same bolt ons except mine has a "stall", why do I say "I think I have a stall" well because I had to replace the tranny once and when removed we found out it had a red stall a yank but im not sure on the size, so all mods are even except mine has a stall and a magnaflow exhaust with pacesetter headers and his has ebay replicas of OBX headers with an slp catback
This could be due to a shift kit.
I would be more concerned about a car made on Monday morning.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Where in Texas are you located? i can point you in the right direction for multiple local tuners that are damn good at what they do. Dont trust some mail order tune, thats the same as putting a superchips programmer on your car tunes cant be one size fits all every car is unique and a street or dyno tune would be the best thing.
I know of Tuners in Houston, and Austin an in dallas you have Tick and you can just drive there.
damn.. well Save money Drive to Reckart Performance Tuning in austin get a dyno tune and just do a cam install while your at it. Brian is a retailer for Livernois and England Green.
Are u driving his car when it feels stronger or are u the passenger? I know ive been in my friends lighting and as a passenger it feels like it pulls like a mf and puts u in the seat but i can turn around get in my car and put 3 car lengths on him, didnt notice this persay till i had a friend DD me home in my car and i told him to get on it and i was like wow **** my car pulls hard, dont notice it as much driving, idk cause ur ready for it or holding the wheell but
