doing headers should i do MM and what kind?
im getting ready to have my headers installed cause i dont have time to do it ....with my work,
so im stocking up and everything i may need.
should i also do motor mounts? if so what kind?
poly? or rubber stockers?
pros and cons of each?
thanks guys!!
thanks guys!!
most people say to do them at the same time to make it easier and the shop would probably charge you less for the install of the MM because they are already their and have the exhaust out of the way, i didnt do mounts when i did my headers but when i pulled my motor a few months ago i noticed that the mounts def needed to be replaced. the polys last longer and are stiffer so you might feel a little more vibration then you do with the rubber ones.
absolutely do them while you are doing headers, i did polys and love them. its obviously rougher especially with the poly trans mount but the car just feels so much better and solid. you will be happy.
I just had headers done. After reading on here last second I had the mm done. I had the polys installed. The car is much stiffer at wot and the only differnce is a little rougher idle. I mean hardly noticable because they are much stiffer then stock. I was told by my tuner that the stock ones are shot at 30-40 k sometimes. I have 100k so I did them. So glad I did hope this helps
ok polys are it then...Im thinking with as many miles as I have...it cant be any worse....HELL...it might even feel better! LOL
so so where is the best and cheapest place to get them.
this car is going to feel 100% night and day.
gonna do headers, LS6 intake and PP TB, mounts, new plugs, wires and a dyno tune,
I wonder what i'll get out of all that
When I installed LT headers, the heat they generated had actually accelerated the wear on my motor mounts. Within a short time, a primary started to rub the k-member and drove me nuts! I ended up installing poly mounts and a poly trans mount. My recommendation is to do both at the same time. I was amazed at how solid the trans felt after that poly mount and my headers didn't rub anymore so I was happy.
