Plug change help
Anyways, I removed the air tube and got all the bolts removed from the coil bracket to move that (attempted passenger side first since drivers looks like a cake walk) and its loose but it will not move? It moves a little bit up and down but not like people said where I can move it to the top of the intake. So first question what am I missing here?
Next question, I got 1 wire and plug out, tried to get the next one in line and couldn't get the damn plug wire off, so what is the trick to getting these stock plug wires off in this tight space? If I can't even get the 2nd one from the front off I will never get #8 off lol, so I need advice here.
Thanks guys!
I run long tubes and did not need to pull the coil packs.
Good luck, Johnny
As for wire removal, they definitely get hard to remove after being in place for 10s of thousands of miles. I pull them off the coils first because that's a bit easier, and then wrap the wire around my finger and pull as hard as possibile. Last time I changed plugs I had to do this with all 8 wires, and only one of them came apart....which was fine because I intended to replace the wires anyway. Some dielectric grease on the new wire boots will help with future removals.
