317 OR 243 Heads LQ4
I currently have 317 heads on my LQ4 but I have the option to possibly get some 243 heads.. Can anyone tell me what mite be better for my application.. Like I said I am currently running LQ4 motor with 317 heads, MS3 cam shaft, Full exhaust w/ LT's, LS6 intake (I believe) and 150 shot NOS..???? Thanks
317s OR 243s????????????????????????????
317's and 243's flow just about the same amount of air. The big differance is the cumbustion chamber size. The 243's have a 64cc combustion chamber and the 317's have a 72cc combustion chamber. So on the LQ4 with a dish piston and 317 heads it's at 9.5:1 compression. Stick on some 243's and you'll bump up to 10:1 copression range. More compression more power. 317 vs 243 one is not better than the other, it's just what is the better head for the application.
Thank you Conan you are very helpful and with that info I think Ill stick to my 317s due to the compression factor.. I eventually want to go FI so dont I want lower comp..???
In short, If you're planning on boosting it, I'd just keep the 317s and not spend the extra $$ for 243s.
