After SLP lid install car won't idle, dies?
Installed an SLP lid and smooth bellows on my 2000 T/A today. I wasn't able to get the IAC out of the original air box, and to move the car into the garage, turned it on with no IAC in the SLP lid and let it idle for a second, where it started at 1100, then fell VERY quickly to 600, 300, and at that point I shut it off. Is the IAC the sole problem? I'm having difficulty getting the original one out since it's stuck in with a grommet. Any ideas what else the problem could be? I had to slightly modify the lid opening for the MAF with a Dremel since it wasn't perfectly round, but cleaned it fully and sanded it down, before I put the MAF into it. Car is my DD, so help is appreciated!
I've done this mod a few times. you can't pry the entire rubber grommet out with a screwdriver or dremel it out? I'd disconnect battery for a while. Connect and fire it up, let the computer relearn the flows. Will temporarily run soft for while, no drama
Tried to get it out with a screwdriver but it didn't work. I'll give the Dremel a try tomorrow if it doesn't start up fine, again.
If you can't get them out worst case just get new ones, IAT is # 12160244 and the grommet is # 24504388.
And when you went to put the MAF on the lid, did you use the hair dryer method?
Nope, just used the Dremel to fit the MAF into it. Used WD40 and a torch as well beforehand, then cleaned it off prior to using the Dremel. I'll likely just order a new grommet and IAT sensor
Cleaned the MAF sensor with MAF cleaner, checked all of the piping and there's no way air is getting in anywhere. Tried holding pos/neg battery terminals together for 5 seconds to reset the battery, etc. Keeps gradually losing starting power, now taking forever to turn over. Starter is only 1 year old, alternator is virtually brand new. Figuring out how to attach a video, now...
So I charged the battery up last night and started it today while a SnapOn diagnosis scanner was plugged in. The only code the car now is throwing is The P1637 Generator L-Terminal Circuit code. Is that a major problem? Haven't test driven the car yet, only let it idle since I have class this afternoon and don't want it to die on me when I'm driving, but should I be wary of anything?
Well I drove the car all day today and nothing seemed wrong, scanner showed nothing besides the P1637 code, so I'll be wary of the alternator but for now it seems alright. Also picked up an IAT sensor so I'm all set now to put the SLP lid on the car!
I know that when I put in my SLP lid I was gettig idle issues and the car would die when I rolled to a stop if I didn't give it some gas while idling. Turned out I had damaged the tip of the IAT when I pulled it from the stock lid. I had no more idle issues once I put a new sensor in...
