Functional Ram Air Question
I just bought a Ram Air II hood and the opening on the front of it are functional. The openings are just above where the lid takes in air. My question is that it lets water into the engine area is this bad? For those of you who have this or the raptor aftermarket hood for the trans ams does the rain get on the engine and if so does it hurt anything?
Adressing the water in the engine area: Trans ams w/out the ws6 hood also have openings in the front that air goes through - the two bottom holes. So water can still get in the engine area even if you don't have a ram air hood. Its really not anything to worry too much about. Where you run into problems is if water gets through the filter and actually inside the engine. Then, you've got trouble.
Originally Posted by Tiger2o69
I know you can buy ram air kits for after market ws6 hood bus i dont know if they are exackly the same as the oem.
are they better than lids?
There's basically two routes to go:
1)get a lid (of your choice) and a induction kit either SLP, FTRA (Fast Toys), or SSRA (Austin's Super Sucker)
2)If you have a WS6, you could go with the kit that seals the air box to the hood (BGRA?)
Hope this helps
Hope this helps
Originally Posted by poweredbyv8
oh ok yeah i get it. thanks ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
who makes the best raimair? i've been looking at the BGRA since i have a WS6
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by 2quick2angry
I got a hood+air box from www.ramairhood.com. I haven't installed it yet though. The thing about it I didn't know when I bought it is that you can't use the stock shocks to hold up the hood when it's open. It says it'll cause the hood to warp after a while, and also void the warranty. You have to use a prop rod (which they include). Are all aftermarket hoods like that?
What are they (being ramairhood.com) making their hoods out of that they are that heavy? Most aftermarket ones I have seen are fiberglass and are lighter than stock hoods. I'm assuming it's the weight of the hood that will cause it to warp and not something else.
Originally Posted by Kenafin_02TA
Hoods from US Exotics don't need the prop rod. I friend of mine is running one and was able to us the stock hood shocks/springs. Don't know about other vendors though...
B I just got my 2000 ws6 and all it has is k&n filter, and a Borla 3in. cat back. any suggestions on how to get the most power without completely breaking my pocket?
![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
Originally Posted by 2000ws6hurst
B I just got my 2000 ws6 and all it has is k&n filter, and a Borla 3in. cat back. any suggestions on how to get the most power without completely breaking my pocket? ![Guns](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_guns.gif)
a lid and the cags delete if you've got an m6. tires are also a good idea
hey what about the FRAM, free ram air mod, like you go inside the RAM AIR and take out the metal that is restricting the air. Several people have told me to do this, is it bad and does it let water in on the engine?
