what do you think it'll run?
What do you think it will run in the 1/4 and 1/8? Im going to a 1/4 next tuesday and 1/8 the following saturday. What should i expect from it?
2000 Z28 A4:
-Dynatech SuperMAXX ceramic coated long tube headers
-Hooker 3” y-pipe with Dual 3" electric cutouts
-Flowmaster cat-back
-ASP underdrive pulley
-MTI lid
-K&N filter
-Hypertech programmer
-Hypertech 160° thermostat
-Ported throttle body
-Throttle body bypass
-Stock descreened MAF
-Cold air mod
-EGR mod
-4.10 gears
-BMR panhard rod
-BMR control arms
-Granatelli Motorsports G-Load Brace
-Removed front swaybar, spare tire/jack, and rear/passenger seats
-15x3½ Weld Pro Stars on MasterCraft 165R15 tires
-15x8 Weld Pro Stars on BFG 275/50 drag radials
Whats next to put this car into the 11s?
2000 Z28 A4:
-MTI lid
-K&N filter
-Cold air mod
-EGR mod
-4.10 gears
-BMR panhard rod
-BMR control arms
Originally Posted by LSONE
i'm sure you'll be runnin into a broken 10-bolt if u plan on using drag radials.
It is true. I say low 12's/high 11's, too. The tires are the main things.
-Todd
i have two sets of tires to use
-BFG Radial T/A 295/50R (street tires) The best 60' i've had with these was 1.95. The 2-3 shift solenoid went bad so i never got a good 1/4 run.
-BFG 275/50 (drag radials) I just got these tires for free so i havent ran them at all.
The car originally had 2.73 gears so it has a steel driveshaft. I've been told the its worth one tenth from a steel driveshaft to an aluminum driveshaft.
Originally Posted by camarodave98
id say high 11's low 12's
Dont know about even being close to 11s. Im guessing a mid to high 12. One way to find out though.
Hate to be a party pooper but I think about mid to upper 12s a lot is depending on your driving and if you can hook up. You want 11s ? Pull out your pocket book. 12 bolt, slicks and nitrous shoud do.
Just have fun and rip up a few mustangs while R at it.
Let us know how you do.
i don't see why you wouldn't be close to low 12's on dr's that is...you've got gears headers and intake...that should put you in the mid upper 12's right there...with the 4.10's the tires i think would make a big difference..but i'd expect on making only one or two passes...if that...since your 10 bolt will be sure to break on sticky tires.
