??????Which one is better for daily driver LT1 or LS1??????
This is a very opinionated question,so i will give you mine.The ls1 is a better daily driving engine,oh and before i forget its a better performing engine that gets better gas mileage,is easier to drive with stick,and is way more popular than the lt1.The lt1 was a popular engine up till 98.Then everything shifted to the ls1 and if people think the lt1 is still the more popular engine then they need there calenders changed ,and there head examined.I have lots of experience with both engines and the ls1 is better in every aspect.
It's not mine! woo hoo!
Originally Posted by 777
ls1 def. it is lighter, better gas mileage, more power...the only reason i would go for an lt1 being nice for daily driving is the large amount of torque it makes WAY down low
As far as the torque down low on the LT1... some people might feel that's less streetable.
Originally Posted by jrp
havent you asked this question a billion times already just worded slighty different.
to answer the Q, i dont know jack bout the LS1.. but i do know the LT1. i can only add this.. after 130k, ive had to replace the optispark, ignition, waterpump, tranny, rearend, alternator, driveshaft, heater and hoses, radiator, thermostat and reprogram the PCM just to keep it as a daily driver..
i would also like to mention that some of these replacements (as i am a do-it-yourselfer) were a REAL pain in the ***!!
Originally Posted by z98
LS1 makes more torque than an LT1.
LS1 > LT1 in almost every way.
And its newer, and it doesn't have a faulty ignition system.
piston slap
PCV problems/oil consumption
M6 hydrolics are weak (98-00)
returnless fuel system
ls1's do make more power but the LT1 is cheaper out of the box and mods are cheaper
but what side effects are caused by piston slap?? Isn't it more of a nuisance than anything else?
Same with oil consumption......still need to get myself a catch can , that helps.
but does have-
piston slap
piston slap
except for that garbage opti i wouldve thought they were equally reliable.
knowing the cost of that part and that it could go at anytime would discourage me from buying an lt1.
some people wouldnt care and just fix it when the time came.
i knew a few lt1 owners that got alot of mileage on their cars with an original opti.
overall an ls1 is more efficent and more reliable due to a better ignition system.
but does have-
piston slap (all years)
PCV problems/oil consumption (all years but 98-00 are the worst)
returnless fuel system (all years)
The PCV problems are again, another thing that's not a huge problem. The LS1 is known to go through oil. So what. Check your oil and add accordingly. Best bet is to buy one of AMW's catch cans. Again, not a big deal.
Probably the biggest problem the clutch hydraulics. But when you put a new clutch in (which everyone will need to do), you just replace them. Again, it's not a big deal.
Think about how many LS1 vehicles are out there. Think about how many people are on this site. Stop worrying and start driving!
SN95 Director
Originally Posted by DMNSPD
They aren't really big problems like people inflate them to be. Piston slap is heard of, but really doesn't cause any problems. And as many people that supposedly have it, the majority do not have the problem. If you have a car and don't know anything about it, then why worry?
