boost, compression....etc
Old Dec 20, 2004 | 09:28 PM
&?EE^&#05+'s Avatar
Default boost, compression....etc
I have a 99 firebird formula, and recently bought a d-1sc serpentine kit, 42 lb fuel injectors, and a holley fuel pump. Everything is stock on my car, just wondering how much boost i could run on it, what compression ratio is best and how to go about getting it there
Old Dec 20, 2004 | 09:33 PM
Flaminchiten67's Avatar
Might want to try the Forced Induction forum.
Old Dec 22, 2004 | 12:29 AM
jrp's Avatar
jrp
SN95 Director
well stock CR is 10.1, if you plan for different heads or ristons you can make it whatever you want.
Old Dec 22, 2004 | 07:15 AM
777's Avatar
777
you are limited on boost...once you get rods and pistons though you can run 1000hp...the stock crank seems to work quite well...at least for harlan
Old Dec 22, 2004 | 02:04 PM
zamboxl's Avatar
ok well stock don't run any more than like 4-5 psi, as far as compression goes if you want you could do 11.1 plenty of plp are doing it so should be fine
Old Dec 22, 2004 | 02:27 PM
777's Avatar
777
idealy you would want anywhere from 8.5-9:1 cr that way you can run high boost
Old Dec 22, 2004 | 08:00 PM
BlueSix's Avatar
I'm going to go against the grain and say you can safely go 8 lbs of boost at the factory compression level. Just make sure you get a good tune and run good gas. Bolt on a set of 6.0 heads and you can run even more.
Old Dec 22, 2004 | 08:21 PM
jrp's Avatar
jrp
SN95 Director
theres no doubt you can, the question is for how long?
Old Dec 22, 2004 | 08:54 PM
BlueSix's Avatar
With a good tune and high quality 93 octane gas i bet it would a while. It wouldn't be the kind of combination you could beat on all the time. Some on this site have proven the stock bottom end can handle a lot of stress if the tune is right. 01-Z is an excellent example of this.
