shitty gas mileage?
ive been gettin horrible gas mileage, like 180 to a tank, and im not gettin on it at nearly at all, what gives? i try to **** at about 2grand, sometimes i will give it a WOT run but will that effect my mileage that much? should i replace the pulgs? or is there any thing else i could do to help it out?
thanks
thanks
i've noticed the same thing.....most of my driving is city miles and only put my foot into it every once in a while. I drive it pretty conservatively. I'm getting about 16 miles/gallon, which seems about 2 miles lower than it should be (my friend gets about 18 with his 98Z and he drives the hell out of it). I'm getting the plugs and wires changed next week, I'll let you know if it makes a difference.
Copy & Paste Moderator
Things to check/replace:
* Spark plugs & wires
* Fuel filter
* Air filter
* O2 Sensors (usually the problem)
Other things:
* run some fuel system cleaner (some good dedicated stuff, not just something you just add to the gas -- I cant remember one off hand, ask around.)
More expensive possiblities:
* Injectors
* CATs
* MAF
* Fuel filter
* Air filter
Other things:
* Injectors
* CATs
* MAF
recently swapped the fuel filter in my lt1.... was getting 20 mpg..... last tank of gas after the swap 26 mpg ![Mr. Cool](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cool.gif)
i just went thru and changed every freaken fuel filter on every car and truck me and my family owns(6 all together
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
There are four O2 sensors.
There is one before and after each of the two CATs.
You dont have to go back to the dealership to get some.
You can get Bosch units from any auto parts store.
O2 sensors are the most common cause for bad mileage, studdering, or performance loss.
I also get about 16 with driving mostly around town. I'm just going to change the fuel filter, plugs and new front O2's when I do the exhaust. Hopefully I'll end up with better gas mileage and more power.
i only need to replace the front 2 correct? bc those are the ones that read my lean/rich data. and i will not buy bosch 02 sensors as i have read they are crap..im going with the stock delco or delphi(same company)
what do the back 02 sensor even do?
Easy to replace, unless they are rusted on in which case you will have to fight them. Last time I changed mine I used a small jack to turn the socket and break one of the loose. Daily driving through winter in the salt/rust belt will do that.
You do only need to replace the front two. Most of us with exhaust work only have those two. The rear two are there to monitor the function of your converters. It compares the data from the first and second two to see how much the cats are reducing emissions. Then if your cats go out, it sets and engine light.
ha, thats exactly what I'm getting on friday, a new set of MSD's and NGK's........I guess I'll just see if the plugs make a difference then decide about the O2's......I have 50k on the stock plugs and wires and they are in bad need of replacement anyway.
Originally Posted by LightEmUpLs1
bought a fram fuel filter yesterday and plan on skipping school tomrw to put it in
along with goin to tdp to get the clutch bleed for 20bucks ![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
high school is pointless though, i dont think i learned a single thing i didnt either already learn in middle/elemtry, or tought myself prior.
