Free ram air mod on WS6?
If I did the free ram air mod where you cut out the bottom of the lid under the air filter would it create to much turbulence from the air coming in from the bottom and the air coming in from the hood? Or is it the more air the better?
Moderator
No, not better if the "more air" is hot air from the
radiator (which it will be, at every stop light).
If you want to improve the "ram air" system check
out removal of baffles (if it doesn't rain a lot) and/
or the "BGRA" which I think may be out of production,
but you could duplicate from pictures.
The External Engine forum is where you'd find most
of the information, if you were to search up the
pros & cons.
pros & cons.
Originally Posted by blue01ta
If you drive it in the rain don't remove the baffles. You will take on water.
I don't. I have a WS6 with all baffles removed and the nozzles sealed to the lid. Run an oiled filter with a clear lid and have run through torrential downpours with no issue. Filter gets a little wet but no water or condensation inside the clear filter. I wouldn't run a paper filter like that though. Could rip.
