BIG MOTOR with stock 2002 Camaro tune?
Old 01-19-2007, 07:04 AM
gollum's Avatar
Default BIG MOTOR with stock 2002 Camaro tune?
Would it possible to drop in a big cubic inch motor that will run perfectly using my 2002 OEM tune. It seems if you design a cam that would keep engine vacuum in line with stock it would work. If I wanted to I could simply use a hand held tuner to do some simple tuning. What is the perfect combination to make this work?
Here's my future EDITED wish list:
427 using GM's new iron block.
243 HEADS and LS6 Intake and Throttle body
STOCK TUNE
Which Cam ????????????
Old 01-19-2007, 07:30 AM
Moderator
JasonShort's Avatar
you're kidding, right?
Old 01-19-2007, 07:34 AM
Stang's Bane's Avatar
I would have to think at the very least the fuel values would have to be bumped way up?
Old 01-19-2007, 07:35 AM
LS1Tech Sponsor
hellbents10's Avatar
Why not have it tuned if spending money like that on a motor????
Old 01-19-2007, 09:02 AM
DONAIMIAN's Avatar
I hope he is.
Old 01-19-2007, 11:12 AM
Chicago Crew UnderBoss's Avatar
Dude, no, not even close it will run like complete **** if it even runs at all and will be WAY DOWN on power and you risk grenading the motor also. Do it right and get it dyno tuned by a profesional for $400 for crying out loud!!
Old 01-19-2007, 11:18 AM
Hennytime's Avatar
Originally Posted by DONAIMIAN
I hope he is.
id think a person with that any posts would know a thing or two...
Old 01-19-2007, 11:42 AM
c5ls1vette's Avatar
I have to agree.
Old 01-19-2007, 01:17 PM
NoRice's Avatar
Here's my future wish list:
LS7 or L92 heads
STOCK TUNE
Cam ????????????
do use a favor and dont think anymore
Old 01-19-2007, 01:28 PM
gollum's Avatar
The above quote makes sense because of the higher flowing and larger intake runners of the L92/LS7 heads. But what if I use stock 243 castings with my current LS6 intake and throttle body. Fuel values should not have to be changed. I am just adding more cubic inches to a stock 2002 SS Camaro. Everything else would be stock, even the cast iron exhaust manifolds. What grind cam will make this work?
Old 01-19-2007, 01:34 PM
Hennytime's Avatar
waste, wont even hit 400rwhp
Old 01-19-2007, 02:02 PM
If you didn't add anymore fuel, then you wouldn't make any more power. To make more power you have to burn more fuel. The extra cubic inches would be a complete waste of money.
IMHO if you did grind a cam to make this work, it would be much SMALLER than a stock LS1 cam.
Old 01-19-2007, 02:06 PM
66deuce's Avatar
you would have 80 more cubic inches to feed fuel and air..so yeah,fueling would have to be increased,especially at the upper rpm range..
Old 01-19-2007, 03:09 PM
gollum's Avatar
I am sure the car will make more power even with the slightly lean stock tune, just guessing atleast 400 hp/ 420ftlbs torque at the rear wheels.
I also think the cam would have to be slightly larger than stock to do this, much like 212/220 duration @.050, 114 lsa, 520 lift, just to keep engine vacuum equal with the stock LS1 so to work with the stock tune. A smaller than stock cam would create TOO MUCH vacuum I think. Would too much engine vacuum cause a problem for the stock tune?
Old 01-19-2007, 03:29 PM
wizardstar's Avatar
I don't understand why anyone would want to do that, stoke tune + 427CI WHY?!?!
I agree with MTI \/
770Guy's Avatar
wont work.
Old 01-19-2007, 03:42 PM
Kleeborp the Moderator™
MeentSS02's Avatar
The short story - don't do it.
Don't cheap out on this one. If you want a stock tune, keep the stock motor. If you are paying the amount of money a big inch motor costs, you can CERTAINLY afford to have the damn thing tuned correctly. I don't get why people insist on cutting corners on something so important. It'd be kinda like buying a huge motor, and using a straw that you blow in yourself to pressurize the fuel system because you didn't want to spend the money on a fuel pump. The tune is just as critical as a fuel pump would be to the engine's operation and life expectancy.
The last thing I'd want to do is chance blowing a motor that cost so much...
Old 01-19-2007, 03:45 PM
gollum's Avatar
I agree with MTI \/
Just trying to come up with a simple low RPM big motor combination that I know will make lots more torque than stock and have verygood drivability using my quiet running OEM 3.42 ring and pinion gear. I can always change over at a latter date to a bigger cammed, higher revving beast.
Old 01-19-2007, 03:55 PM
MeentSS02's Avatar
There's nothing wrong with doing that...just get it tuned. A good tune could be thought of as protecting your "investment" (if putting money into a car can even really be called that).
Old 01-19-2007, 04:09 PM
gollum's Avatar
All I am asking is "would it be possible". This idea would not be be risky at all if air/fuel ratio and spark advance are within limits. A drop in large engine combination that requires no tuning sounds like a vergood idea to me. It may or may not work but it is a good idea any way you look at it.
Is it possible KATECH?
