Ticking From Lifters?
Scammer Alert!
i ran my car at the track sunday and on my last run, right after i made my pass i heard someticking, not very loud but constant, i asked some guys and they said that its coming from my lifters, so i ran some sea foam in my oil for about 10 minutes, changed with new oil used 4.5 quarts with 1 quart of Risolve, and a new filter, still making the ticking any ideas, please help
Scammer Alert!
hah, i just want it gone, i mena its a big deal to me and annoying to boot, so the longtube header bolts, ill have my mechanic check that out hopefully thats all it is
It could be a header leak, a lifter, a rocker arm, or a bent pushrod. Maybe you over revved it and a valve touched a piston.
I would pull each rocker off one at a time, check the pushrod for flatness on something flat, like a mirror, and inspect the rocker. Also check the pushrod ends. Then put it back together and check lifter preload. Try to put the pushrod back in the way it came out, with the same rocker because they had been worn together.
Scammer Alert!
ok heres the soundcli[p video kinda sux but atleast you can hear the noise, i stopped at a shop prior to posting this and he said a lifter, what brand, type lifters would you guys prescribe, i heard comp makes some hydraulic roller lifters any ideas, without further ado heres the clip
http://www.youtube.com/watch?v=a79COMLGwZU
