disappointing track times...
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I ran my car for the first time yesterday at the track. Here's what I got: 99 Camaro SS with 3.23's A4 and Pace Setter Long Tubes 3 in ory magnaflow cat back and SLP lid. I also had drag tires on. My best run was a 13.47 at 102. everyone on here told me I should run around a 13 flat. anyone know what up?
the 60ft will tell a lot, but also your sea level and track. my car doesnt see anything better than 8.80 on the 1/8th, and im about 100ft below sea level, but i know my track sucks a lot, so my 60ft are about 2.5 or more.
gotta post your 60 foots and the track. some tracks arent i the best of shape as far as maintenance and prep are concerened. if its a slow track in general and your 60's are 3ound 2.3, or 2.4 that would explain alot
I was also disappointed the last time I went. 13.42 with near 2.3 60'. Im an M6 and try to go as hard as I can while goin easy off the line. If you know what I mean. I was hopin for at least 13.1's. I was on street tires though
the track says it all.. here where i live the tarmac on the track is so bad that whe have no grip at all, my cars spisn wheels in 1 2 and 3rd gear, i havnt got under 2.5 in the 60's, went 13,7 on my m6 car and was wjheru disapointed, but that was when the car was bone stock with a fried clutch, raced my friends 02 m6 car last frday went 13.6@108 = no grip, good power,
i think 13.42 is a fine time, but 102mph is not that good on a ls1 car
Originally Posted by slowjoe99
2.14 60'. and the track was in roggersville MO at night probably around 75-80 degrees...
It sounds to me like you need a dyno tune. I know that after I had my LT's put on my car was running like crap and only trapping 101-102. I got it on a dyno and found out I was only making 270 RWHP with a 17:1 AFR. After some tuning New Era Performance got the car down to 12:1 AFR and up to 300 RWHP (through an unlocked converter BTW).
After that my traps were 108-109
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Good luck.
A short and dirty explanation is density altitude. It tells how thin the air is at a given moment.
A track with high elevation high temperature and high humidity will have thin air therefore a high DA.
A track below sea level, with cold temperatures and low humidity will have very thick air therefore a low or negative DA.
