View Poll Results: What is your LS1 block holding, or been know to hold?
300-400hp
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
8
12.90%
401-500hp
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
11
17.74%
501-600hp
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
23
37.10%
601-700hp
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
7
11.29%
701-800hp
![](https://ls1tech.com/forums/images/polls/bar6-l.gif)
![](https://ls1tech.com/forums/images/polls/bar6.gif)
![](https://ls1tech.com/forums/images/polls/bar6-r.gif)
3
4.84%
801-900hp
![](https://ls1tech.com/forums/images/polls/bar1-l.gif)
![](https://ls1tech.com/forums/images/polls/bar1.gif)
![](https://ls1tech.com/forums/images/polls/bar1-r.gif)
1
1.61%
901+hp
9
14.52%
Voters: 62. You may not vote on this poll
What had the stock LS1 block been know to hold?
I am thinking about taking my stock 2000 t/a, and make it into a twin turbo monster, but i would like to know whats the LS1 block good for, or what you are running it at. Because what i am hearing is that some people have luck, and others dont.
Roofer Dave was over 1000hp on a stock block and crank. I believe that's pretty close to the limit for both. I would change to an Iron block around 1000 flywheel hp for safety.
Originally Posted by Benjamin Russick
My current 383 is well into the 600rwhp range on spray. My factory bottom-end lived with 576rwhp for 3 years before pushing a head gasket. It looked perfect on tear-down...
ok, here is the next question, should i change to a an LQ9 iron block, 4.0" Stroke 4.0" bore to make a 402ci. Would i be better off with that engine? This engine that i am looking into is for a twin turbo set up...
Crankshaft: Callies COMPSTAR 4340 material forgings 4.0"
Rods: Manley? COMPSTAR?
Pistons: Diamond? MAHLE? Lunati? JE? Manley? 4.0"
I know i need low compression, so i still am deciding in a set up, throw some ideas out there?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Figure out what you can and want to spend first.
IDK what your other expiriences are, but I am pretty sure a basic old iron 408 with a healthy shot would be enough to scare the crap out of me for years. And thats a nice cheap build that just plain works.
Originally Posted by LrngCrv
didn't an rx7 on that HotRod streetrod drag competion get over 1300 hp on an LS1 with a twin turbo setup and pump gas?
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
Originally Posted by slammer454
yeah, i remember that, lemme grab that mag..... yeah, 8.22 @ 164, 402CI TT setup. that should move. ![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
These engines really are well made, with a little bit of work they can handle some serious power and do it fairly reliably
Originally Posted by staringback05
these bottom ends can actually hold alot, it really depends on the tune
Originally Posted by Ericbigmac83
You found that magazine fast, lol
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
