ASP pulley vs SLP pulley
Moderator
I like the SLP/March/powerbond pully better than the ASP. They have a larger lip which helps to keep from throwing a belt. If you get the ASP, I would get a KTech tentioner for it. I gained 12rwhp & 12rwtq with the SLP pully.
Originally Posted by RoWDyWS6
do u got to buy a new belt for a pulley swap??
Originally Posted by mcamarols1
do u have to remove, the radiator ect. ect, to install the pulley or can u do it from under the car w/ a lift?
I personally like the march unit the best. Sfi approved, Fluid dampened. Comes with new gm bolt, black powdercoat. Very nice unit. Id go slp before asp. And i went March before slp. There both gonna do about the same thing, but supposibly the fluid dampened march pulley will not cause the spark sensor's from retarding timing.
Thunder racing is the only sponser that sells the march pulley. Its 199.99 by itself, or 229.99 for the pulley, and both belts you will need. (great deal)
The march pulley seems to be cheaper than both the slp, and asp pulleys, and everyone that has run it absoultly loves it. I have seen dyno's of 12hp, and thats what they claim.
Getting the crank bolt out isn't to bad, getting the pulley off the crank is, and getting the new pulley on the crank is worse. Plan for a long day of frustration..
good luck
Chris
Originally Posted by bad6as
slp and power bond are the same. the newer asp pulleys are better then the older ones and i think their also lighter then the stocker and slp
Moderator
March, Powerbond and SLP are the same pully. The ASP is not SFI approved last I knew. They did also have issues with throwing belts, but that may have been fixed. Throwing belts can be fixed with a Ktech tentioner.
Chris
I have been using the same ASP pulley from my old car and now on this car since I think it was 02. Ive been happy with it and have had no problems with the belts coming off KR ect. ASP is good in my book.
same here. 5+ yrs. with no problems.
