How much Oil!
Old 01-09-2008, 11:07 AM
flemshady's Avatar
Default How much Oil!
How much engine oil does the 4th Generation take. 5 or 6 qts?
Old 01-09-2008, 11:11 AM
fuseone's Avatar
i know on a ls1 with not using the bigger type of oil fiilter its 5.5 quarts
Old 01-09-2008, 11:16 AM
bryan04h's Avatar
the book says 5.5 quarts, but you can safely use 6 quarts with a normal oil filter
Old 01-09-2008, 11:23 AM
black01_WS6's Avatar
I run the longer oil filter and 6 quarts of oil.
stock 5.5
Old 01-09-2008, 11:41 AM
flemshady's Avatar
Would it do damage if you just used 5? Just wondering?
Old 01-09-2008, 11:50 AM
777's Avatar
I would rather have more oil than not enough. But to answer your question I doubt it. You just need to keep check since the ls1's typically burn some oil in normal operation.
Old 01-09-2008, 11:57 AM
cabech984's Avatar
No, but I wouldnt try it! 5.5qts, PF46 or equivilant filter, PF61 use 6 quarts. Cant go wrong with the generals specs!!!!
Old 01-09-2008, 12:46 PM
ReFtheMC's Avatar
5.5!
Old 01-09-2008, 01:01 PM
30thanniv's Avatar
Ok, they should sticky this question already.
This is the easiest way to do it if you forget. I know I always forget.
Go through the normal oil change procedure and filter replacement.
When you are filling up the crank case with oil, USE the dipstick.
Give it a chance for the oil to drain properly and USE the dipstick.
Sounds pretty easy, right?
GEEEEEEEEEEEEEEEZ
Old 01-09-2008, 01:55 PM
bryan04h's Avatar
hmm, you figure there would be a faq in general maint and repairs....because this should be in one
Old 01-09-2008, 02:02 PM
SOMbitch's Avatar
GEEEEEEEEEEEEEEEZ
HaHa. That's why it's called NEWBIE TECH man!!
Old 01-09-2008, 05:58 PM
pitbull14218's Avatar
i used 6 but i only did one oil change to my car since i owned it. I heard too much oil is worse then not enough.
Old 01-09-2008, 06:12 PM
30thanniv's Avatar
My bad
Maybe a sticky for the sticky is in order
DOH!
Old 01-09-2008, 06:15 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
I use regular size filter, and 6 quarts. Always have.
Old 01-09-2008, 06:57 PM
Chicago Camaro's Avatar
one time a sales rep at murrays told me to use 5 quarts....
Old 01-10-2008, 01:05 AM
Wsteun's Avatar
As long as it falls in between both marks on the dipstick, you're fine.
Old 01-12-2008, 12:31 AM
fuseone's Avatar
yea i would just do the 5.5 with the normal oil filter. and it can do damage with to much oil
Old 01-12-2008, 02:33 AM
MJK
MJK's Avatar
Just use 5.5 quarts and a standard filter...What real reason would there be to stray from what is the factory recommendation unless you are running something totally different from stock.
Old 01-12-2008, 03:16 AM
jetlag's Avatar
5.5, but sometimes when I'm feelin' frisky I'll put 5.6 in it...if you know what I mean
Old 01-12-2008, 08:25 AM
the ls1 has oil issues, and if you have lower oil and go racing around corners you can actually damage the motor as the oil system can't keep up with the g-forces. Most of the road race guys I know use 6 quarts with the stock filter or change the whole system- but that is a little overboard for a DD.
