what cam package to buy
my bad, forgot in wasn't in my sig. 2001 camaro ss stock with:
free mods, lid, ported heads (flow at 308), lt's w/offroad y, cutout, magnaflow exhaust, 3400 fuddle, 3.73 gears. and i will be ordering underdrive pulley's for when the cam is installed.
if you have stock valves you will be fine. a fast intake would help, but seeing as you have the ls6 intake stock i think you will be fine. if you are worried about streetability then all you need is a tune. if $ is a huge issue you could get a mail order tune from tsp that should get you by. obviously it is not better than an actual tune but many people are satisfied.
with your set up, the cam will have no problem breathing so you should make some big power. if you wanna go a bit smaller the tr224 is a proven cam that is good for a dd. however you will not make the kind of power the ms4 will
I wouldn't run the MS4 unless you have at least a 4400 stall. Remember max power isn't the only thing, you have to have the right gear and stall and other mods to get the cam to work right with the combo.
The MS4 will make more power at a higher rpm, but a smaller cam with your stall will actually make more power at "that rpm" than the MS4, will so it will leave harder.
