Car temp jumps when I get on it.
My engine temp guage will jump a little bit when I get up on it. Not much, prolly about a 1/8 of an inch past 210. The fans kick on and it pretty much instantly goes down, I just worry about small stuff. Should I just not sweat the small stuff? Is this something I should look into?
What do you suggest?
Thanks!
Thanks!
You can reprogram the PCM and have the fans kick in sooner. Or you can install a manual over-ride switch turning the fans on when you think the car is running hot. Search on this board, there is a link posted with a diagram. My car before the mods used to do the same thing as yours.
it's totally normal, it's just that these cars have a linear temp gauge so you notice it more.
i would consider a PCM tune, a colder stat and a coolant flush if you are concerned/
thats strange my car doesnt ever go above 210 beating on it or not its always at the same temp lol am i the oddball? like mentioned above though i wouldnt do anything but make sure u have good coolant and that fans are kicking on when needed!
