Questions about O2 sensors
My confession of the day is that I really don't know anything about O2 sensors. How many O2 sensors does a stock LS1 F-body have? 3? What are the advantages of deleting them and how would I go about doing it?
I went to Autozone and asked about O2 sensors, and they were around $75 each or something. Is that the price for one? I'm throwing a P0131 code and I don't know which O2 sensor to replace.
I'd do a search, but I'm having difficulty finding the right keywords. Searching "O2s" doesn't really help.
Thats your driver side O2 then. You can see it when you open your hood. Should be just behind your steering shaft on the manifold. Get a new Bosch or AC Delco sensor and replace it. With the O2 sensor socket, takes about 15 minutes. Its alot easier going under the car and doing it. I just replaced both of mine.
F-body comes with 4 O2 sensors. 2 for each side, one before the cat and one after. The primary O2 ( before the cat) monitor the exhaust gases and determines fuel delivery. Secondary O2's (after the cat) are purely for emissions purposes.
So the rear O2s can be deleted without any other modification? Would it be fine to just replace one primary O2 or would it be a good idea to replace them both?
LS1TECH & Trucks Sponsor
You can just replace the one. before the cat, driver's side. Bank 1 is driver's side, Bank 2 is pass side. sensor 1 means pre-cat, sensor 2 means post cat.
Before buying one, swap the driver's sensor with the passengers and see if the code moves with bank 2 sensor one, so that you know for sure it's the problem
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Personally, Id replace them both. You dont HAVE to, but Id rather have 2 sensors that I know are new, in good working order and reading the same levels of exhaust gases....But, if you cant afford, replacing the faulty is perfectly OK.
Correct you can delete the rear O2, but you have to have the codes deleted that are associated with them as well.
Well, you "turn them off" using software. Any performance shop that works on LS1's should do it for you....I believe it sets them in a "ready" state meaning the ECU always thinks things are ok.
Most likely....You may be able to get them from the top, but I honestly have no idea. I put LT's on my car a few weeks after I bought it and I can get to my O2 sensors with no jacks now.
