Wiring Harness & PCM Compatibility
I am speaking with regards to '99+ cable throttle PCM's and wiring harnesses. I have a '01 LQ4 that I am swapping into my '89 Camaro and am trying to figure out what my options are, as far as the wiring harness and PCM go.
So, are all '99+ cable throttle truck wiring harnesses compatible with the '99+ cable throttle car PCM's? For example, would an LQ4 engine/trans harness work with a '99 LS1 Corvette PCM? How 'bout a 5.3L truck harness, with the 'Vette PCM?
why use the vette PCM? if your going with the 5.3 harness why not use the 5.3 pcm? or is it called an ecu on a gm, well whatever......the 5.3 computer is just as programable as the others to my knowledge.........
Well, that could change everything... And I think you're probably right, at least according to this(DBW mentioned in the last paragraph).
Hmm, so I guess that leads to the question: Can I use this '99 'Vette PCM with any of the newer truck DBW harnesses?
Another question: Could I flash this '99 Vette PCM to a cable throttle OS and use an F-Body harness? I thought I read somewhere that certain DBW PCM's don't have an IAC driver (which would be needed for a cable throttle setup), but that may have been only for later years... Or I could be totally off base altogether...
Found where I read that... But that is with regard to 1meg PCM's, a '99 Vette PCM is 512kb according to this article... So, I guess my question still stands...
Last edited by BlueIroc-z; 07-15-2008 at 09:32 PM. Reason: Wanted so say something else...
I sent an e-mail to Speartech with some more specific questions about my situation. I'll post the answers here, it might be of some use to someone down the road.
It's cool, thanks for your help. I was leery of throwing this out in the PCM section, thought it might be too nooby of a question.
Anyways, here's what Speartech had to say:
The Corvette PCM can easily be reprogrammed to work with a 99-02 F-body cable throttle harness.
It is not compatible with the 03 DBW truck harness. That uses a different style PCM and DBW throttle body.
All of the earlier PCM's (99-02) had drivers to support both DBW and cable throttle.
