looking for a new clucth
so far this is what im thinking
Ls7 clucth kit ( pressure plate, Disc and Flywheel)
slave master cylinder
master clucth cylinder
pilot bearing or throwout bearing ( help with this lol)
tranny fluids
now i have a few ?
as far as brand goes which are the better brands for a good price
also anything else i would need such as seals or bolts ????
i have a 98 trans am M6
stock for now but looking to get LTH and Ls6 intake in the future
tranny fluids
now i have a few ?
I don't have any experance with the ls7 clutch but every thing i've read about that clutch has been good. Get a slave for the 02 fbody. The throw out bearing is what pushes the fingers on the pressure plate to disengage the clutch plate. You'll want to replace the throw out bearing when you have every thing apart. The pilot bearing is in the center of the fly wheel and the input shaft of the trans goes in that, replace that too. When i pulled my engine for the first time the seal in back of my trans was leaking with only 27k on the clock. so check yours before you pull the trans. I used GM'S syncro mesh for the trans fluid and i replace my seal with GM's as well. While the trans is off you'll be able to see if the rear main seal for the crank is leaking too, if so replace because you have to have the trans out to do so.
From: Your girl's back door giving her the long stroke while you're at work
Most new slave cylinders come with a throwout bearing anyway. I had the LS7 setup in my TA when it was still a 6 spd and loved it. It never gave me problem in the city or the track.
Check the Manual Transmission Forum as well.
Get A Ram Clutch You Wont Regrett It I Had Spec All The Stages And When I Went To Ram It Was Just A Way Better Clutch But The Ls7 Will Hold For Awhile Until You Start Doing Things To It
Sums it up pretty good!
Spec Stage 3+. Hands down the best clutch for a street strip car. Had all others, and nothing compares. Done many 6400 RPM dumps with slicks, and never had a problem. Just my $.02
