View Poll Results: Seafoam my engine?
Hell yeah seafoam that bastard!
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
81
84.38%
Ummm no save your money.
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
15
15.63%
Voters: 96. You may not vote on this poll
Seafoam engine? YES OR NO?
Just wondering if running that stuff through my 143K mile ls1 will hurt anything? Also whats the best way of doing it, pouring it in the tank or disconnecting a vacuum line and pouring it in the intake?![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I use that stuff in my truck and yea it actually works pretty good the hesitation and my service engine light went off when I used this stuff. I have not used in my camaro but a couple of times I think I got like 1 or 2 more mpg. I just poured it into my gas take straight. Dont pour it in a vaccum line you will hydrolock the motor and it will stall. If you do use it on a vaccum line you have to have a I.V. type deal that will drip into the vaccum line slowly. Hope this helps we use the fuel injector cleaner stuff at N.T.B works good looks like your car is getting I.V. Fluids lol.
Absolutely. About what 98z28hispanic said above about not putting it into the vacuum line, absolutely do this as well. Just pour it in slowly and stall the engine out with the last gulp. There is a good writeup around here somewhere, just search.
By the looks of the gunk on the throttle body of the 82k mile LS1 I bought for my Z28, I felt the need to seafoam through the vacuum line four times in the past 4 months, and did the oil treatment twice.
I seafoamed and did it through the brake booster line and also the gas tank.....IMO i don't think pouring it in the crankcase is wise although people have done it many times like this with good results however i don't think it's a nessesary thing to do.
Ive done it on my camaro,
1/3 gas tank
1/3 vac line
1/3 crank case ( then oil change shorty after)
ive also got my co workers hooked on that stuff. and now gona start charging people 10 bucks to do it (my coworkers that is)11111
1/3 gas tank
1/3 vac line
I've done it on a few cars and I've noticed the more you race the engine the less **** comes out. Your burning up more of the carbon that builds up when you race it than if grandma was only driving it to get groceries every day.
Whenever i do mine, i put it in a cup, take the tube off the booster, and put it in the cup, I've never hydrolocked my motor, you just cant let it idle. Works great!!!
My car runs fine but im thinking about doing sea foam then oil change and plugs for a good tune up. My car has 114k miles and it has not ever seen anything like sea foam. My NGKtr55's have about 30k on them so im thinking doing all this at once will add some power.
