Helppp Rear Tires!!!!!!!
I CANT TAKE OFF EITHER OF MY REAR TIRESSSSSSSSS!!! WTFFFF!!
I have the rear lifted and its almost like the rear wheels are welded on.
Is there some lock or trick to taking them off?
I have beaten the **** out of them with a sledge hammer and to no aveil PLEASEEEEE HELP PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
:ba ng:![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
:bang :![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
corrosion F T L . try sitting down facing the tire and kick the sidewall repeatedly or grab another wheel and tire hold onto it and swing and hit the sidewall of the tire that is stuck.
When a car comes in to our shop with this problem, we grab a hammer(short lead hammer, packs a better punch) make sure your car is lifted and has jack stands supporting it. Lay down under the rear bumper and hit the outer lip of the rim and spin slowly an continue this. Should come off fairly easy. Make sure your doing this from the inside as well if i didn't make that clear enough. Good luck.
I had this problem before when I had an older style 10 bolt and was putting new ws6 wheels on. They have a smaller inside diameter and the rear has to be sanded a little to get them on. What year car is it and what type of wheel is it?
btw jsteele90....i needed a good laugh
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I've heard of the parking brake with drum brakes holding rear wheels on pretty tight.
Though now that I'm typing this I'm thinking you'd have to have your wheels set right on the thing for that to matter at all. Maybe it's just a wives tale.
