Car won't start, or even crank...
Battery is brand new and still checks out good. Alternator was good as of a week ago. Pulled the starter, it tested good. Now what?
When I turn the key, all I get is a simple click. No crank, nothing.
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
just behind the battery on the fender well there is a red cover where the battery cable goes through. i had mine get a little coroded around there on my old 93 firebird and it did the same thing. i pulled the cable off both ends and just put a bolt in it and it strarted and no problems after that. good luck
went into quick trip came out to start the car all lights came on but would not start, would not turn over. towed it to dealer wires in steering wheel going to ignition switch some were broke. they put in a new key switch fixed the wires $460.00 later works great.
reset your ecu...i have the same problem every now and then. turn key on, pull out pcm bat and pcm ign fuses, take key out,...5 min later, put fuses back in and crank 'er.
https://www.mygmlink.com/pdf/go2cont...1998camaro.pdf It's for a 98 but I think they're the same as the 99. Fuses section is 6-66 and 6-67
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
you try cleaning the cable ends that go into your side post? ive had alot of problems with mine being corroded to the point were it will run accesories but wont start the car. all you get is a click. i usually just put dielectric grease on it and it cures it.
