do i need bigger injectors
Old Oct 23, 2008 | 09:12 PM
02b4ccamaro's Avatar
Default do i need bigger injectors
im fixing to install a tr230 and 5.3l stage 3 heads on my 02 z28, and i was also thing about a 100 shot. so heres the the question will i need to upgrade to a big injector and fuel pump.
Old Oct 23, 2008 | 11:35 PM
Gimp98TNT's Avatar
If you are running a dry kit you will need to do bigger injecters, and fuel pump. If you are using a wet kit then all you need is a bigger fuel pump.
Old Oct 23, 2008 | 11:50 PM
Duffster's Avatar
Wouldn't this statement need more info to be based on something. . . like how much the injector duty cycle is being used?
Old Oct 24, 2008 | 12:20 AM
Gimp98TNT's Avatar
Since he didnt specify what he was running I assumed he was running stock injectors and s stock fuel pump. If he is running stock stuff still, he will need to upgrade.
Old Oct 24, 2008 | 08:50 AM
im going to run a wet kit and the injectors, and fuel pump are stock
Old Oct 24, 2008 | 09:20 AM
Nick@HSW's Avatar
More than likely you'll be fine with the stock injectors. Just have your duty cycle logged while its being tuned. I would definitely do a fuel pump upgrade.
Nick
Old Oct 24, 2008 | 11:04 AM
Midnight02's Avatar
Like the others mentioned above, if you're going with a wet kit, you should be OK with the stock injectors, however a fuel pump upgrade is recommended. If it was a dry kit at 100 rwhp, it's worth checking your injector duty cycle during the tune, because you will likely need to upgrade them.
Old Oct 24, 2008 | 11:44 AM
Sprayed 99's Avatar
i'd say see what the duty cycle is on the injectors after the install. i had injectors from a 2002 z28 and they weren't big enough. i'd recomend goin bigger and just be done with it
