direct port Nos
Old Feb 24, 2009 | 08:13 PM
firehawk1082's Avatar
Default direct port Nos
whats the bet direct port setup, im leaning toward the zex, anybody try that kit out yet?
Old Feb 24, 2009 | 08:17 PM
jeepers_88's Avatar
How big of a shot are you wanting to run?
Old Feb 24, 2009 | 08:28 PM
prob start with a 100 and move up in the future
Old Feb 24, 2009 | 08:54 PM
evilbeef54's Avatar
wait now im confused the title says NOS but you are asking about the ZEX kit, which one are you looking at...
j/k
what intake are you using? what is your price range you are looking at? wet or dry?
Old Feb 24, 2009 | 09:51 PM
98zonjuice's Avatar
I actually just bought the Zex kit for my FAST 92/92 Setup. I haven't done anything yet, but it looked like a nice clean set up.
Old Feb 25, 2009 | 10:17 AM
Nick@HSW's Avatar
Unless you're looking to move up significantly in shot size, I would not recommend a direct port system. At that shot size, the fuel jets are really small and very susceptible to clogging, especially with a high pressure fuel system. Take a look at our single nozzle or plate systems as they will be more than capable of meeting your needs.
Nick
Old Feb 25, 2009 | 11:01 AM
1.8t's Avatar
^ If you were going to go with a DP dry would there be any better/safer way to do a 100 shot than a DP setup?
Old Feb 25, 2009 | 12:12 PM
Nick@HSW's Avatar
Absolutely you could nix the fuel end of the nozzle and go dry direct port but it would require the use of some sort of controller or ecu to control the fueling end of it. You wouldn't have the issue of the small fuel jets either. Problem is that there is a significant cost involved for something that can easily be obtained via a single nozzle or plate type system. What were you looking to do?
Nick
Old Feb 25, 2009 | 06:30 PM
jeepers_88's Avatar
i say save your money for bottle fills and get a wet plate kit, they work really well
Old Feb 25, 2009 | 06:36 PM
dnkynrbk's Avatar
I would just go with a wet plate. DP should be 250 or more shot.
Old Feb 26, 2009 | 02:00 PM
1.8t's Avatar
Nick
Not necessarily looking for anything as of yet. Mainly just compiling ideas and different paths. I have been contemplating throwing a kit on my car and I am only consdering a dry setup. I have complete tuning abilities at my fingertips already since I have the full HPtuning suite. With the stock bottom end, I would go with a plate kit/dry setup since I am not too keen to flowing fuel through the intake mani. I am just always "nervous" about nitrous distribution through any means of manifold application because a quick reading of my plugs shows cylinders 5, 6, and 7 leaner than the rest. Obviously nitrous would just exacerbate the issue and while nothing would likely happen with the miniscule shot I would run(~75hp or so), there may just be more risk than I am willing to take at this moment.
If I ever decide to build the motor, I would go for a DP dry setup. I likely wouldn't be spraying more than a 200, but the safety would be worth the added expense for me.
Old Feb 27, 2009 | 04:12 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
NOS/NS brand Direct ports.
Available in soft plume 90* or straight discharge.
Old Feb 27, 2009 | 05:39 PM
evilbeef54's Avatar
flowing through the intake on a dry setup can be done safely, and from the advice HSW is giving you unless you go with a much bigger shot through the intake would be the safer way to go over DP with such a small hit. If you are worried about individual cylinders running leaner going with a DP set up isnt going to fix that issue since you will be sprayng the same into each cylinder. What i would do is get a temp gun and start fixing your individual cylinder fuel trims since as you said you have acess to the tuning software. Get the cyl trims balanced out and that should help your concern. Are you doing any datalogging? and how much leaner are we talking on these cylinders?
