best injectors for 125 shot on stock motor?
Old 03-11-2009, 02:32 PM
badazzt/a's Avatar
Default best injectors for 125 shot on stock motor?
was wondering what # a hr would be the best to put on a stock motor. it's a m6 with mac mid-length headers.
Old 03-11-2009, 02:57 PM
bowtiy's Avatar
if thats your only mods, and your taking about a (dry) kit you would be safe with factory injectors. if you have a (wet) kit, the nitrous has its own fuel supply and the motor will not rely on the injectors for the xtra fuel. with stock 28# injectors i put down 433.1rwhp N/A, and with a 150hp direct port wet kit it made 591rwhp...injector selection depends on you power goals.. i have since switched to 42# injectors for a more radical N/A set-up ... keep in mind you will need a tune after larger injector install..
Bowtiy
Old 03-11-2009, 07:06 PM
badazzt/a's Avatar
what about the tr6 plugs? are they a necessity? the car has 110k on it to i dont know if that makes a difference on the injectors or not!
Old 03-11-2009, 07:28 PM
98zonjuice's Avatar
Yes, get the plugs.
Old 03-11-2009, 07:52 PM
jetlag's Avatar
Not with those lil dinky 26# injectors.
Old 03-11-2009, 10:23 PM
badazzt/a's Avatar
what injectors would u use jetlag?
Old 03-11-2009, 10:28 PM
jetlag's Avatar
Are you using a dry kit or wet kit?
I was refering to a dry kit when I made that post.
Old 03-11-2009, 10:42 PM
badazzt/a's Avatar
yea im using a 125 dry shot.
Old 03-11-2009, 10:46 PM
jetlag's Avatar
Your stock injectors will definitely be maxed.
I have SVO 30# red tops and will be using a 150 dry shot + bolt ons listed in my signature. Also, you should probably upgrade the fuel pump.
Are you using the HSW Interface for fueling control?
Old 03-11-2009, 10:49 PM
badazzt/a's Avatar
what it be a good idea to use the hsw interface? if so then i will, it's what pulls the timing back when ur spraying and advances it when ur not correct.
Old 03-11-2009, 10:52 PM
jetlag's Avatar
Yeah, the Interface is awesome. I am running a plate kit with it.
Well worth the money!
Old 03-11-2009, 10:55 PM
badazzt/a's Avatar
wheres a good place to get a plate, cuz my broter in law works at holley and he's the one that is getting me a deal on the system, and it comes with everything but a plate.
Old 03-11-2009, 10:57 PM
jetlag's Avatar
Holley owns NOS, do they not sell the plate separately?
Harris Speed Works or Nitrous Outlet make plates.
You may find one used in the For Sale section.
Old 03-11-2009, 11:00 PM
badazzt/a's Avatar
yea he said he could get me one but i didnt know if maybe theres a better plate to use. im sure there all the same.
Old 03-11-2009, 11:03 PM
badazzt/a's Avatar
and where would be a good place to get the hsw interface?
jetlag's Avatar
Well, all the companies are going to be biased for their own piece.
The NOS plate has the outlets on the driver side, and I had my nitrous lines coming on the passenger side and didn't want to swap around.
I went with the HSW plate because it was cheaper and had side outlets and they were having a sale also..hah. I plugged one side.
Here is my thread.
https://ls1tech.com/forums/nitrous-o...th-bellow.html
Old 03-11-2009, 11:29 PM
badazzt/a's Avatar
did u have to have ur car tuned after u done all ur mods??
Old 03-11-2009, 11:32 PM
jetlag's Avatar
No, my car has only had some shift points changed and a few adjustments for the torque converter. No performance tuning at all.
