June Nitrous Specials at Nitrous Outlet
June is here and it is time to get started on those summer time projects. There is no better time than now to increase the horsepower to your Pride and Joy. For the month of June we are offering discounts on our Total packages.
Group 1.
Brand X Single Nozzle Package- Includes Brand X single nozzle system with 10lb bottle, automatic bottle heater, purge, fuel pressure safety switch, nitrous pressure gauge/manifold, NHRA fitting, blow down tube, Nitrous Filter and Digital window switch with built in TPS activation and gear lock out features.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=941)
Normal Retail- 913.57
Special Price- 799.00
Group 2.
LSX Plate System Package- Includes Nitrous Outlet 78mm, 90mm, or 92mm Plate system with 10lb bottle., Billet bottle bracket and Automatic Bottle heater combo, Purge, Nitrous pressure gauge, Fuel pressure safety switch, NHRA fitting, blow down tube, Nitrous Filter, NGK Spark Plugs and Digital dual stage window switch with built in TPS activation and gear lock out features.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=935)
Normal Retail- 1,262.00
Special Price- 1,100.00
Group 3.
LSX Dual Stage Plate System Package- Includes Nitrous Outlet 78mm, 90mm, or 92mm Plate system with 10lb bottle., Billet bottle bracket and Automatic Bottle heater combo, Purge, Nitrous pressure gauge, Fuel pressure safety switch, NHRA fitting, blow down tube, Nitrous Filter, NGK Spark Plugs and Digital dual stage window switch with built in TPS activation and gear lock out features.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=944)
Normal Retail- 1,578.00
Special Price- 1,400.00
Group 4.
LT1 Plate System Package- Includes Nitrous Outlet Stock, 52mm, 58mm or mono blade Plate system with 10lb bottle., Billet bottle bracket and Automatic Bottle heater combo, Purge, Nitrous pressure gauge, Fuel pressure safety switch, NHRA fitting, blow down tube, Nitrous Filter, NGK Spark Plugs and Digital dual stage window switch with built in TPS activation and gear lock out features.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=938)
Normal Retail-1,311.01
Special Price-1,150.00
Discounted Accessories.
1. F-body Spare Tire Mounting Bracket-
This specially designed Bracket bolts in the spare tire area between the frame rail and antenna bracket providing a safe, flat and solid mounting surface to bolt your bottle brackets to.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=953)
Normal Retail-51.52
Special Cost- 44.00
2. F-body Transmission Tunnel Bracket
This specially designed Bracket bolts to the transmission tunnel between the rear seats. Provides a safe and solid mounting surface to bolt your bottle brackets to.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=986)
Normal Retail- 74.99
Special Cost- 64.00
3. GTO Trunk Bottle Mounting Bracket
This specially designed bracket bolts to the frame support located behind the carpeted firewall. Provides a safe and solid mounting point to bolt your bottle brackets to. This bracket suspends the bottle in the air so you have full use of the trunk.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=1009)
Normal Retail- 99.75
Special Cost- 85.00
4. C5 Corvette Bottle Mounting Bracket
This specially designed bracket epoxies to the fiberglass floor providing a solid mounting surface to bolt your bottle brackets to.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=1006)
Normal Retail- 75.00 per side
Special Cost- 64.00 per side
5. Rail Upgrade for 4 or 2 solenoid direct port
The Nitrous Outlet Rail Upgrade is designed to provide a unique and clean looking install for your direct port. Available in 2 solenoid and 4 solenoid configuration. Includes Rail Fittings.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=968)
Normal Retail-150.00 per rail
Special- Cost- 100.00 per rail
6. Remote Bottle Opener
The Nitrous Outlet Remote Bottle Opener works on just about any brand Bottle. A must have when the bottle is mounted in the back of your street car!
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=980)
Normal Retail-252.82
Special Cost- 199.99
7. 78mm LS1 Plate Conversion
The Nitrous Outlet 78mm plate conversion will flow well over 400 hp worth of nitrous. No other plate on the market measures up to our plate. This design offers the cleanest looking install, best fitment, best distribution and highest flow.
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=1003)
Normal Retail-272.99
Special Cost- 235.00
8. 860 Hot Water Box
The 860 Hot Water Box is a computer controlled hot water bath for your nitrous bottle. Since the hot water heats your bottle down to the core the bottle pressure maintains longer than any bottle heater can provide. Set it and forget it.. A must for the track!
![](http://www.nitrousoutlet.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=965)
Normal Retail- 621.61
Special Cost- 525.00
This special is good until June 30th. You can place your order by calling Toll Free 1-866-648-7637 or 254-848-4300. On the accessories we have changed the website pricing to reflect the special price. So you can order them on our website if it is easier for you. For Group packages please call in our order so we can make sure to get you exactly what you need.
Thank you guys so much for your support…
See you at the track!
Nitro Dave
Group 1.
Group 2.
Group 3.
Group 4.
Normal Retail-51.52
Special Cost- 44.00
Special Cost- 64.00
Special Cost- 85.00
Nitro Dave
This is exactly what I have been waiting for. Is there any way I could change out the window switch in Group 2 for an FJO progressive controller, and pay a little extra? I would also be buying the transmission tunnel bracket.
