projected vs non-projected plugs
Old Jan 16, 2010 | 10:04 AM
  #81
ATVracr's Avatar
Originally Posted by streetassasin
https://ls1tech.com/forums/generatio...ap-please.html
Can someone help me out here? They are recommending a tr-6 for a h/c 150 shot 6.0
maybe after a few years of posting that you should NOT run them with nitrous stupid people who dont really know will stop throwing out random advice that will potentially burn someones **** up.
Worst part is the poor guy who posts up and asks the question ASSume these guys are experts and take there posts as gospel.
***** crazy
Old Jan 16, 2010 | 04:20 PM
  #82
TheGovernorZ06's Avatar
ATV,
what hp level would u stop useing a br6ef and switch over to a br7ef? over 150hp shot?
Old Jan 16, 2010 | 04:33 PM
  #83
ATVracr's Avatar
Depends on how much HP it makes on motor.
We run 7's in my motor N/A ... if we ran a 150 shot we would run 9's
A aggressive H/C motor with 150 shot I would use a 7.
There is almost no HP difference between a 6 and 7 so why not use the safer plug?
With a 7 in there you will run just as fast as you will with a 6 but may have 1 or 2 more degrees of timing.
Old Jan 16, 2010 | 05:37 PM
  #84
Robert56's Avatar
Originally Posted by TheGovernorZ06
ATV,
I agree. it's not really a matter of over all HP, really. It's a matter of a projected tip plug not being correct for nitrous, end of story. You could get away with the TR6 and a 200 shot, but that doesn't mean it's correct or the best route to take. I also run a BR7 as my daily plug and my motor n/a is only 430rwhp and it works fine (lower HP or VE compared to ATV's motor). The LSx has a pretty good ignition system so running a recessed tipped plug it will still ignite the mix fine, remember how good these motors are in the VE area. A motor of past and crappy inefficient heads might have issues using a recessed tipped plug in place of stock extended tip plugs. This is where some of them blanket statements that try to cover everything comes into effect. The TR6 may be the best plug for other motors when needing colder and keeping an extended tip plug, but not optimum or needed for the LSx and spray. The LSx from the get go, has a whole new set of rules when tuning for the spray, IMO, compared to the motors that fall into the old blanket statement suggestions. This includes a/f ratio, timing, and plugs...
Robert
Old Jan 16, 2010 | 05:55 PM
  #85
not too sure how much it makes on motor, but i do all my own tuning (EFiLive) so i can tune a br7ef w/o any problems as a daily driver... and ive tuned the car to run on br7ef before...
so, i guess just run a br7ef and call it a day? or have a few tunes one for a br6ef and a br7ef...
Old Jan 16, 2010 | 05:57 PM
  #86
Robert
excellent statement.... much agreed
Old Jan 16, 2010 | 07:19 PM
  #87
TJ's Avatar
TJ
630 or so crank hp here. i use a 7 plug. well actually i use whatever the parts store has if i dont have a back up.
i try to keep 2-3 sets of plugs just so i dont have to hunt when i need them.
Old Jan 17, 2010 | 10:20 AM
  #88
disc0monkey's Avatar
ATVracr, he didn't mention that he daily drove the car but I have a feeling he does, would you still recommend the 7? robert, i know im beating this to death, so if the car is tuned to each plug will you see much difference in mpg and idle between the 6 & 7. i have 7s in my car now but ive been waiting on injectors for three weeks now :/
Old Jan 17, 2010 | 04:22 PM
  #89
Yes i daily drive the car weather permitting...
Old Jan 17, 2010 | 11:09 PM
  #90
Robert56's Avatar
Mine would be right around 500bhp. On the spray I have been to 741bhp and 824tq at the crank. The short block is built to handle 1000hp including a 300/350hp n2o shot, so i have plenty of room to grow. This leads me to my next couple questions in my quest to make 500+ RWHp n/a, like you have. On your 408 what heads did you decide to go with and intake and why? Also, what cam are you running? I studded with the L19 studs, did you do something similar? IIRC, the L19s have a clamping force of 30/40% more than the standard ARP studs. However, I have never had a head lift on any of the LSx combos I have done, but some do at the levels we are spraying. My goal is spray a 350rwhp shot, but so far have only gone to 300, have you been past this point yet? Maybe ATV stated sometime back that he did a 325 or 350, ATV? Then if either of you have gone over 300hp any insight would be welcome. It seems that at this level things need to be so close to spot on and absolutely the best race gas...
I don't think this is to far from our talk on tuning and may give more insight on what we have been covering. If not forgive me for getting off topic a bit here.
Robert
Old Jan 18, 2010 | 01:50 AM
  #91
Robert56's Avatar
I really never noticed any difference. My cam is pretty loppy at idle, but a stock car and idle issues is where the few that claim problems seem to think the idle suffers. Even then we think it's just a little ruff idle and not really an running issue? Keep your gap close to .030/.035 for the smaller hits. I actually go a little closer when at the track running the big hits. On the MPG, mine sucks so can't tell you if it suffered, which I doubt it really would much? IIRC, every-time I check the instant MPG on the DIC, it shows like 11/12 miles to the gallon, LOL, maybe cause I am always flooring it?
Robert
Old Jan 18, 2010 | 06:34 AM
  #92
ATVracr's Avatar
Robert, we have sprayed over 400 without any head gasket issues.
If the tune up is correct you wont have any issues there, detonation is what causes them to lift not cyl. pressure.
Ours is a 4 bolt set up with std. size ARP 2000 studs, cometic gaskets.
Old Jan 18, 2010 | 06:57 AM
  #93
Robert56's Avatar
Wow, that sounds very promising. I am running the GM MLS gaskets as was rec by a GM engineer buddy. Some prefer Cometic, but I am not so sure they are superior to the GM stuff. Your thoughts?
Really, you think only detonation will lift a head? or push water? In any case I have not pushed water, lifted head, blown out gaskets or none of that fun stuff, LOL, nor on any set-up I helped with. So I am not an expert in that arena, and hope not to find out the hard way. I didn't have any idea you guys went 400 already, congrats.
Robert
Old Jan 18, 2010 | 08:07 AM
  #94
ATVracr's Avatar
Robert
Never used them so I dont know, we have always used cometic and never had an issue. We dont fix what aint broke.
We have sprayed close to 500 on Shiz's motor 2 years ago and not lifted the head or pushed water. We are going to a 6 bolt set up this year so that 475shot on his 4 bolt motor will be the limit that we know of on a 4 bolt set up. I honestly think that if the tune is right the head gasket/lifiting is not an issue.
Old Jan 18, 2010 | 10:08 AM
  #95
Robert56's Avatar
yea, I have to agree. not much room for error at those levels.
Robert
Old Jan 18, 2010 | 10:24 AM
  #96
ATVracr's Avatar
Robert
You aint just whistling dixie there buddy !
Old Jan 18, 2010 | 11:09 AM
  #97
TT632's Avatar
Minor clarification, but you know this anyway; Detonation will cause a sharp uncontrolled rise in cylinder temperature and pressure. This higher then normal pressure and the area that it reacts on, results in a force that can exceed the limits of the head bolts/studs and lift the heads, cause head gasket failure etc.
Old Jan 18, 2010 | 11:24 AM
  #98
Robert56's Avatar
Yes, ask my bent LS6 rod how it liked the detonation, LOL, at an already pushing it 685rwtq.
Robert
Old Jan 18, 2010 | 07:57 PM
  #99
TJ's Avatar
TJ
Robert
tfs 235 cylinder heads with a super victor intake. 4150 carb.
cam is a pat g spec. its fairly tiny, but runs like a bandit.
247/255 624 624 on a 108 icl.
"PRAY" is a user on here and has a simialr setup in his z06.... it put down 575/530, about the hp i figure mine would do if i wasnt eating up dyno power with this auto and big stall.
i have a set of lightweight pistons in the motor, and with the material they are forged from, im limited to around a 200 shot on this setup, but thats all i ever planned to really go anyway. still tweaking on motor. i want to get the most out of it before i put the nitrous back on this motor. i know once the plate gets bolted on, n/a times wont matter anymore.
Old Jan 18, 2010 | 09:49 PM
  #100
A3VETTE's Avatar
I daily drive my car and ive had 8s in mine for the past 3 months and really didnt see an issue until it got really cold here (low 30's). And the only issues it had was upon start up after leaving the car alone overnight. The idle was a little choppier than usual. Once warmed up it was fine.
Robert
LOL wow! I only noticed a slight drop in mpg, like 1-2 with the converter locked when I went from TR6's to NGK 8's non projected plugs. I still get above 25 mpg from 60-75 mph. City sucks around 15-20 converter unlocked under 50 mph.
