boom!!!
Old Jan 2, 2010 | 01:35 PM
pozesd99''s Avatar
Default boom!!!
so yesterday my stock bottom end decided to let go
so now im in a pickle on what to do.
thinking of doing a 370ci iron block by tsp. spraying a 250-300 shot through 2 kits.
how do the 370's respond with spray???
im gonna be running heavily ported 243 head, which cam do you suggest, i was thinking ms4 cam. would i need to fly cut the pistons?
im thinking +12 dome pistons with 62cc heads to bump the compression up...
what will my final compression be?
and what is a reluctor wheel?
here is a link to the motor.
and suggestions what my options??
see link below....
http://texas-speed.com/shop/item.asp...d=683&catid=83
Old Jan 2, 2010 | 03:32 PM
rickou812's Avatar
see link below....
Old Jan 2, 2010 | 03:36 PM
pozesd99''s Avatar
pics of what??
Old Jan 2, 2010 | 03:38 PM
puggerton03's Avatar
im guessing he means pics of the blown up engine.
Old Jan 2, 2010 | 03:44 PM
pozesd99''s Avatar
not torn apart yet,but i need advice... im not here to post pics of a blown motor
Old Jan 2, 2010 | 03:52 PM
quews6lime's Avatar
well to my knowing a low compression motor will take nitrous better
Old Jan 2, 2010 | 03:55 PM
red fury's Avatar
Nitrous loves compression! A built motor will handle it unless you get greedy
Old Jan 2, 2010 | 03:58 PM
camscam02's Avatar
Id figure out why you broke it before moving on to something new and doing the exact same thing.
goodluck
Old Jan 2, 2010 | 04:02 PM
jmill96Z's Avatar
Sorry, but your knowing is wrong
Old Jan 2, 2010 | 04:26 PM
BAKED's Avatar
LOL yup.
Old Jan 2, 2010 | 04:33 PM
goodluck
im guessing it broke because it was the stock bottom end.
Old Jan 2, 2010 | 04:35 PM
camscam02's Avatar
and you know this how? Usually **** breaks because of a bad tune up.
Old Jan 2, 2010 | 04:38 PM
because it says it in the first line of his post.
Old Jan 2, 2010 | 04:43 PM
camscam02's Avatar
LMAO. yeah ok.
Old Jan 2, 2010 | 04:57 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
Like camscam stated, he needs to figure out why his stock bottom end let go before spending $$$$ on a new motor. It'll happen AGAIN if he doesn't.
Old Jan 3, 2010 | 12:09 AM
Ruckus46Gt's Avatar
yea figure out what happened that you blew up the bottom end on motor...or did you finally try the kit out
Old Jan 3, 2010 | 01:34 AM
pozesd99''s Avatar
stupid on my part. 4 quarts of oil low lol
but so what options should i do with this 370?
any help is appreciated
Old Jan 3, 2010 | 06:02 PM
BAKED's Avatar
Head studs, MLS gaskets, Good pistons and rods, Spend the extra money on a good fuel system.
Old Jan 3, 2010 | 06:41 PM
pozesd99''s Avatar
i know that and i have all that but was wondering specific motor specs by test...
but might be going a new direction. hke hit me up and we're working something out for my specific needs
Old Jan 4, 2010 | 07:46 PM
ShiznityZ28's Avatar
370's work great. we have a few running around. can put a hellova good nitrous piston on the stock stroke. Spend the time to research guys running small cubes and big nitrous and get a good game plan(whole car) if you throw somehting togeather you will be making this post again...... And the tune is at fault probably 90% of the time.
