Those who are running the HSW Microedge....questions!
I am currently looking at this HSW Microedge controller...
http://www.harrisspeedworks.com/prod...&cat=57&page=1
Instead of getting a window switch and other safety precautions, will this Micro edge cut it for me? Heres a little about my setup...
I have a NOS Power shot wet kit with a HSW plate setup. I plan on getting a bottle heater, fuel pressure switch and a few other little odd's and ends. Im just trying to wrap up with the safety controls before I start the install.
Those who are using the basic level micro edge, How do you like it? How is the install? Thanks for the input!
Jump over to our site and follow the links to tech support and installation manuals. We host all of our instructions online so you can go through them and plan your installation prior to purchase. If you have any other questions just ask.
Thanks
Nick
i had it on my camaro 232/234 110+3 cam and 150 dry shot 3675lbs 3.90s and 6 speed with ls7 clutch was traping 129. i sold my camaro but i put my kit on a friends ls1 notch. and it kicked *** on that too. now using it for a dry dp
You can actually use the a/f shutdown instead of the fpss. The shutdown will actually catch a few scenarios that a fpss won't. You'll also gain the benefits of tps, dual stage control and the option to upgrade to a progressive controller if you need to now or down the road.
Thanks
Nick
Thanks
Nick
