Wet or dry...cant decide
SOME SAY WET IS BETTER AND SAFER....SOME SAY DRY......DRY SEEMS EASYER TO INSTALL AND CHEEPER....I DONT HAVE A CLUE....GOT THE $$ FOR A KIT BUT CANT DECIDE.....THINKING OF GOING W/A NOS OUTLET HALO KIT(DRY) ONLY WANTING TO SPRAY ABOUT A 100 SHOT...........HELP PLEASE............................
Just go with wet man its usually a smoother shot and its better to tune.
You can run as much hp through a dry system as a wet system and neither works better or produces more hp based on the kit solely. They will make power based on the user and the way they go about it.
I like wet on the stock pcms as it is just easier to tune fuel wise IMO, but dry can work perfectly fine. Once you go to an aftermarket pcm such as FAST, BS3 etc dry is the only way to go. So much simpler.
read this for more info
https://ls1tech.com/forums/nitrous-o...ry-vs-wet.html
Wet vs. Dry
These questions will come up alot, so I'll try to address them now. The main difference between the 2 is the Wet kit injects fuel AND nitrous into the intake tract, whereas the Dry kit will only inject nitrous. They both have their advantages and drawbacks. If you're new to nitrous, Dry is probably for you. Its very simple to install, mostly plug and play and gives the most hit. Wet kits are generally a smoother hit comparatively and require more installation. Dry kits do not inject more fuel into the intake directly, but if nothing else was done, your engine would lean WAY out, and thats never good. What the dry kit does is fool the fuel pressure regulator into thinking its not adding enough fuel. It opens it up (or closes it, however the LS1 works)[LSx platform uses the MAF to tell pcm to add fuel thru injectors, and LTx uses reg to spike fuel pressure with aux fuel pump. Robert56] and adds more fuel that way. The problem with this is its very easy to lean out. If the vaccuum line pops off or something goes wrong with the FPR, you can lose fuel and this can damage your engine in no time if the nitrous isnt turned off. Also, you'll probably get people telling you that you cant run big shots on dry. This is not true. USA Motorsports used to competitively race using a 2 stage dry kit 175-300.
Wet on the other hand is the most tuneable of the 2 (not including foggers or direct port, I'll go over that later). It adds additional fuel through a seperate solenoid and atomizes it with the nitrous in the intake tract. This is safer in the sense that you dont rely on the FPR to add more fuel, but the downside is if you shut down too early and do not stop spraying early enough, the fuel/nitrous mixture can puddle up inside the intake and cause a nitrous backfire. If you have never seen one, I hope you never do. They are not pretty. I had one in my old racecar. It was a 250 shot and it blew halfway down the track. The hood was toast, the intake was split in 3 pieces, TB cracked in half and the MAF was blown away somewhere and couldnt be found. Not fun. While this isnt a common occurance, it IS possable.
Also, as far as the MAF registering it, you don't even need to worry about that if you get the interface controller with the dry kit. It does all the work for you and also allows you to pull timing. It really evened the playing field as far as wet vs. dry.
I have always been a fan of wet.https://ls1tech.com/forums/nitrous-o...ry-vs-wet.html
Wet vs. Dry
i was about to post that
